Source for output air cor output inductor?? - diyAudio
Old 17th January 2004, 06:53 AM   #1
sam9 is offline sam9  United States
sam9's Avatar
Default Source for output air cor output inductor??
I've been winding my out ouput inductors. 16AWG, 1-2uH. While this isn't especially difficult, my "craftmanship" isn't the best looking. Search as I might, I cannot find an "off-the-shelf" source. (If I wanted to order 100-1000, that might be another situation!)
Is anyone aware of a source for ready made output inductors? Must be air core and 18-14AWG, 1-2uH.
Old 17th January 2004, 07:30 AM   #2
diyAudio Member RIP
I've never seen them "off the shelf" as they are so easy to make.
For best results use a coil former - anything will do - remove from
the former and then dip in wax or wood glue to hold the coil together.
sreten.
Old 17th January 2004, 06:01 PM   #3
sam9's Avatar
Yup. Pretty much what I've been doing. I've also just discovered that using the theads on a bold of the appropriat diameter and thread-pitch is helpful. Too bad some clever soul doesn't make a 10-ohm resistors specially dimentioned to use as a form. I've made this work on low powered amps, but on higher powered it doesn't work out.
Old 17th January 2004, 06:06 PM   #4
Magura is offline Magura  Denmark
Magura's Avatar
I produce air core inductors to pretty much any specifications. Max 100 mH though.
Send me a mail if interested.
Cheers
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 17th January 2004, 06:20 PM   #5
Steven is offline Steven  Netherlands
Steven's Avatar
Well, it is not air core, but Reichelt sells Fastron inductors per piece. I think these will do with 3.9uH, 12A.
Steven
Old 17th January 2004, 11:25 PM   #6
sam9's Avatar
Steven,
Thanks. It should require a bigger amp than I'm building at present to saturate that.
Old 19th January 2004, 01:56 AM   #7
djk is offline djk
djk's Avatar
The low values required for an audio amplifier can be wound on a 2W resistor, any value. The Q damping resistor is added in parallel.
Old 19th January 2004, 02:25 AM   #8
sam9's Avatar
"The low values required for an audio amplifier can be wound on a 2W resistor, any value. "
Well, that's true up to a point. But if I'm anticipating a 100W-150W @ 8 ohm that also can handle a 4 ohm load, I prefer using 16AWG magnet wire. My Wheeler's formula calculator tells me I need a larger diameter and/or length than any 2W resistor I know of has. 18AWG would do it but could get a bit hottter than I care for. I tend to be convervative about wire guage, heatsinks and thermal maters, generally.
Old 2nd July 2015, 04:29 AM   #9
Banned
I just dug up this old thread. I made and installed the output inductors. But I am a little concern. I used 14 gauge insulated wire and wound 15 turns on an AAA battery. It's already installed on the pcb. I have second thoughts whether that is optimal.
Is 15 turns too much inductance winding on an AAA battery? Or I should reduce a few turns?
Old 2nd July 2015, 07:00 AM   #10
Do you have a target or calculated value of the resulting inductors?
Pronine Electronics Design - Single-Layer Air Coil Calculator
Ian
When an output inductor is needed??? Leolabs Solid State 10 2nd October 2011 11:08 AM
Copyright 1999-2017 diyAudio
