idle current i(bias) is slowly dropping in one channel
Old 20th September 2014, 01:32 AM   #1
jlk is offline jlk  Denmark
Default idle current i(bias) is slowly dropping in one channel
Hi, I have a hk6800 amplifier where the left channel can't keep the idling current bias setting on 39mv. Every 15-30 min. it is decreasing around 1-3 mv. until the sound gets bad. Can it be caused by a bad transistor on the output pcb 5 ?
idle current i(bias) is slowly dropping in one channelHide this!Advertise here!
MUSICAL FIDELITY A2 Quiescent current / Bias problem Right Channel sviru Solid State 23 1st November 2013 06:47 PM
Single supply class AB amp, with two outputs per channel, how much idle current? Welcome Solid State 19 1st June 2013 02:03 PM
bias/idle current adjusting q139 Solid State 30 10th March 2013 11:13 AM
DAC left channel dropping out. A mystery. Pano Digital Line Level 14 21st August 2011 11:03 AM
NAD 3130 left channel dropping in and out as I turn the volume control was8v Solid State 2 1st July 2007 06:16 PM
