lc audio the end and thd - Page 2 - diyAudio
Old 8th March 2002, 08:59 AM   #11
ergo is offline ergo  Estonia
Well, we shall see what the measurements show. I regard the sound of the amp to be of a very good value for the price. I have listened to it for 1,5 years now and just recently I finished two JLH 96 class A monoblocks and these seem to be the ones that outscore the millennium. I haven't been able to do a decent comparison jet though as my cd player is broken at the moment and I'm waiting for spareparts....
Ergo
Old 10th March 2002, 01:33 PM   #12
Default The End Millennium measurements
First the condirions were.
1) signal source: Sony CDP-XE530 cd player
2) passive voltage divider
3) Sony MDS-JE520 for A/D conversion
4) digital input of CM8738 based soundcard to PC
load was either 6 ohm or 4 ohm non inductive resistive load.
The first picture shows the measurement setup base distortion (CD analog out to MD analog in)
http://my.tele2.ee/hifi/millennium/residual.jpg
Also note that the first picture has -130dB range and others have -120dB range
1W into 4 ohm load
http://my.tele2.ee/hifi/millennium/4ohm1w.jpg
10W into 4 ohm load
http://my.tele2.ee/hifi/millennium/4ohm10w.jpg
83W into 4 ohm load (-3dB from clipping)
http://my.tele2.ee/hifi/millennium/4ohm83w.jpg
1W into 6 ohm load
http://my.tele2.ee/hifi/millennium/6ohm1w.jpg
1W into 6 ohm load
http://my.tele2.ee/hifi/millennium/6ohm10w.jpg
1W into 6 ohm load
http://my.tele2.ee/hifi/millennium/6ohm83w.jpg
The quiesent current in my amp is turned a little higher than specified by LCAudio - it is 300mA
Rgds
Ergo
PS. Oh jeah
this is my The End Millennium : )
http://my.tele2.ee/hifi/millennium/myamp.jpg
Old 11th March 2002, 07:45 AM   #13
Oops
Seems I've made some mistakes with descriptions
1W into 6 ohm load
10W into 6 ohm load
83W into 6 ohm load
Ergo
Old 11th March 2002, 04:58 PM   #14
km is offline km
hi.
"cannot find server"........
any chance you can make a scheme like the one on george krilov site , this way it would be real easy to compare your specs with his simulated ones and the published specs from lc audio?
i will of course try late to see if i can access your files.
bye k madsen - cad audio dk
ps. thanks for your efforts....
Old 11th March 2002, 05:41 PM   #15
km is offline km
hi.
it seems that excel file from here is usefull for converting fft graphs to thd ;
http://www.fna.muohio.edu/dogstar/tubestuf/thdconv.htm
ps. if anybody has got the graphs could you please send them to me or upload them to a server? thanks.
Old 11th March 2002, 07:09 PM   #16
km, I'll hope you'll see the files this way...
Residual distortion
1W into 4 ohm
10W into 4 ohm
83W into 4 ohm
1W into 6 ohm
10W into 6 ohm
83W into 6 ohm
Old 13th March 2002, 08:36 AM   #17
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Default Which software
To Ergo....
I take it this is SpectroLab software..
which version and ***. hardware did you use here...????
Best regards
Halgeir
Old 13th March 2002, 10:52 PM   #18
The software I used is SpectraLab 4.32
The measurement setup is Sony minidisk player MDS-JE520 which I use for analog digital conversion. Then the signal goes via optical link to Leadtek Winfast 4X soundcard digital input. For the soundcard I use M Audio Dio2448 soundcard drivers which are much more optimized for the job.....
The signal source is usually my Marantz CD67 but as it is broken at the moment I used friends Sony CDP-XE530 player.
Ergo
Only N-Channel MOSFETs (NMOS); better Audio from non complements by Audio Power? tiefbassuebertr Solid State 49 19th April 2016 03:18 PM
For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp tmort Swap Meet 5 27th June 2009 12:29 AM
Need schematic for Elevation Audio DX1500.1/Sundown Audio SAZ-1500D jaimegmr Car Audio 0 5th May 2009 06:39 PM
Looking for analog audio circuit designers and audio researchers cnotley Everything Else 1 29th September 2008 09:04 PM
2.4GHz wireless audio - true lossless audio Kay Digital Source 0 30th January 2008 10:22 AM
Copyright 1999-2017 diyAudio
