transistor hfe help - diyAudio
Old 11th September 2014, 07:50 AM   #1
Default transistor hfe help
hi,
is it possible to use two transistor constant current source circuit to supply constant current to the transistor base what is being tested.
construct multiple constant current source circuit ranging from micro amps to few milli amps and use rotary switch to select the current we want.
simply use two digital ammeter to measure base and collector current.
will it work?
Old 11th September 2014, 08:54 AM   #2
Send a message via Skype™ to JonSnell Electronic
Hfe is the ratio between the collector current and base current. For example for a power transistor with an Hfe of 70, means that to pass 70mA of collector current 1mA of base current is required. So, to have a constant current supply for the base, selectable as you suggest and measure the collector current, makes perfect sense. The only drawback is knowing the power handling of the device under test and adjust manually as required to avoid damaging the device when testing.
www.flyingmole.co.uk For World Wide support for Flying Mole, Class D, Refurbishment and Repairs. www.jonsnell.co.uk
Old 11th September 2014, 09:24 AM   #3
yes transistor data sheet must be used as a guide to avoid device damage.
Old 11th September 2014, 10:16 AM   #4
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Worth bearing in mind that hfe does vary with VCE, so some way of controlling VCE might be a good idea.
No matter if we meanwhile surrender every value for which we stand, we must strive to cajole the majority into imagining itself on our side - Everett Dean Martin
Transistor hfe ratings sneakers563 Parts 6 25th June 2011 04:41 PM
seeking: 1.5A+ low noise, high hFE transistor riotubes Parts 11 22nd October 2008 12:11 PM
Transistor HFE observations. Zero Cool Solid State 35 26th December 2006 10:10 AM
Bipolar transistor Hfe values k1jroth Parts 19 20th December 2004 04:17 PM
help!! smd transistor's hfe measurement oz_gur Parts 2 16th February 2004 07:19 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
