Sony STR-V333ES blowing power board fuse - diyAudio
Old 7th September 2014, 09:44 PM   #1
slml is offline slml  United States
Default Sony STR-V333ES blowing power board fuse
New to diyaudio. I have a Sony STR-V333ES receiver. I recently moved and after the move the receiver is blowing the fuse on the power board. The relay on the power board repeat clicks until the fuse blows after about 5 seconds. I have started to unplug cables from board to board and have discovered if I unplug the ribbon cablefrom the "Digital-PWB" board that goes to the board on the back of the main unit the clicking goes away and the power can remain plugged into power. I'm not sure what to investigate next. Does anyone have any suggestions? I have not yet unscrewed the board on the back of the main controls. I have heard that maybe a loose solder connection could cause the relay to click. I visually inspected the connections and everything looks OK.
fuse blowing on power supply Holty Power Supplies 9 11th December 2012 04:57 PM
Sony STR-V45L (need help hacking amp board) Tommiduck Chip Amps 3 8th February 2012 11:24 AM
Sony V333ES Amp with a rapid clicking relay and no power fbcds82 Solid State 5 19th July 2011 06:56 PM
No power / repeated blown fuse in Sony STR-D915 dmworking247 Solid State 0 21st January 2008 08:37 AM
Sony Reveiver Blowing Fuse!! Help! Perry1977 Solid State 5 19th March 2005 02:26 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
