Issue While Rehabbing an STA-2100, What To Do?
Old 6th September 2014, 09:03 PM   #1
mikte15 is offline mikte15
Default Issue While Rehabbing an STA-2100, What To Do?
I posted this yesterday on AK but haven't received a serious response, so I thought I try here.
I'm in the process of rehabbing this Realistic I've had for a couple of years. I played it a bit after I bought it but it sounded a bit off so I stowed it away until I was ready to do a full recap. Now that I've started I found one channel must have failed because there were a lot of replacement components. Since none of the components were the same as stock I decided to follow the EW's advice in this thread and go with On Semi replacements.
http://www.audiokarma.org/forums/sho...d.php?t=556573
While doing the amp board I noticed some reconstruction and replacement of the Sanyo 2SD400P (TR506A) that's mounted to the heatsink (left photo). The replacement is not a TO-92 package and there is no stock mounting clip like the other channel (right).
At this point what would you do? Leave the transistor that's there? Order a 2SD400 replacement and DIY a clamp? Are the clamps available anywhere? I couldn't find any.
Old 6th September 2014, 09:32 PM   #2
jerluwoo is offline jerluwoo  United States
jerluwoo's Avatar
Using a different transistor affects the thermal compensation. The larger to220 has a larger thermal mass and will compensate differently than the to92, adding the Vbe change with temperature, this could be a large difference. Using the device the amp was designed for is the best for ensuring it's continued operation. The clamp would be easy to reproduce if you can't find a new one. VR502 in the schematic should also be carefully inspected or replaced, this was a poor design choice, if the wiper goes open the output transistors will self destruct.
Old 6th September 2014, 09:55 PM   #3
Thanks Jerluwoo, I'll plan on changing VR502.
Rather than trying to find a transistor replacement I'm thinking of finding a donor. That transistor seems pretty common.
Mike
Issue While Rehabbing an STA-2100, What To Do?Hide this!Advertise here!
STA-500 Power Amp protect issue XsamuraiX PA Systems 9 4th June 2014 09:23 PM
Just got me a realistic STA 2080 srinath Solid State 16 19th May 2012 08:50 PM
Pioneer STA-2100 Volume Control Knob gouldtv Parts 1 9th September 2008 12:04 PM
Genexxa STA-2170 John Ball Chip Amps 0 22nd December 2007 12:15 PM
Realistic STA-7 receiver rpapps Solid State 8 17th May 2005 01:49 AM
Copyright ©1999-2017 diyAudio
