I have a Classe DR-10 with a couple of shorted power transistors.
Does anyone know of any suitable replacements? I have the service manual but it doesn't give the part numbers either. The transistors are ground down to get rid of the part number .
MJ15024 and 25 according to the service manual. A good upgrade would be MJ21193 and 94. I would replace all in the bad channel. Check page 8 of the SM.
I have the same issue with a Classe Audio 10 (same as dr-10).
Did you end up replacing the transistors?
Any tips that you could give me from your experience? Thanks very much
Shane
