#11 |
I builded my crescendo, the 1982 one from elektuur already two times, but always have the same problem. The crescendo works but after a couple minutes there exist a noisy sharp sound that rises up. and then after about 5 minutes collaps C14 or C15(the big Elco's on the PCB's) only one will explode.I checked the polarity for mor than 100 times, but still have this problem, can anyone help me. I think is't something stupid,
Is there maybe a fault in the chematic that i don't have? I think sombody told me ones there was a fault in the chematic, is it true am I the problem. I hope somebody can axplain my problem, because I builded it complete and it looks very ok, only the sound don't works. I'm from Belgium. |
#12 |
Can you post a schematic so we can see what we are dealing with?
Craig |
#13 | |
Or could be thermal runaway, if not all relevant components have thermal contact. Transistors or diodes for the bias setting often need to be thermally connected to the same heatsink as the power stage or even directly to the power transistors.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#14 |
here i have the chematic from my Crescendo!!!
#15 | |
Yes this is exactly the chmatic that i did use 10 yeares ago, and did use the PBC layout that was in the article
-- http://www.polarboing.com |
#16 |
So do you have T8 and T10 on the same heatsink as T11, 12, 13, 14?
Did nothing from the link in post #13 solve your problem? There is a list of changes and an updated schematic in there with tips on the best location of certain components.
#17 |
Electrons are yellow and more is better!
The gate resistors could be increased to 330 ohms or 470 ohms. I had problems with this.
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#18 | |
no regarding the original numbering of components , attached is one version that I had simulated. It has a few modifications ( ones from Elektor magazine and others from me ) but works well on simulator. eD |
#19 |
eD, the schematic you have posted is not that of the Crescendo but modified version of the Hexfet Amp. Your simulator version has a cascoded VAS and runs off higher rails.
Sam |
#20 |
I've commented on this amplifer before, but here goes again.
This is a 1980's design and back then the philosohy was in general the higher the loop gain the better. Nothing wrong with that point of view, but then you have take some design precautions to ensure the amplifer behaves. There is no dominant pole compensation so the amp perfomance is overly sensitive to layout, component tolerances, EMI ingress etc. On top of that, Mosfet suppliers are notorious for reducing chip size on a regular basis (to remain competitive) and this often affects key parameters like input capacitance etc. On this design, that will impact the stability. This amp could do with miller caps between the VAS Cascode collectors and the bases of the VAS transistor (sorry, cannot read the references on the posted copy - they are a bit blurry). Maybe Bob or Glen want to comment. Anyway, good luck with your amp - if you can get it stable no doubt it will sound good. (My first Elektor amp was the 'Equa' - I think it was about 1978 or 1979 - if anyone has a copy of the schematic, I'd really appreciate it if you would post it). |
| JLH - Pass - Krell clone - Cresendo what sounds best | Kees | Solid State | 84 | 16th September 2003 07:36 AM |
| PICS: GainClone Monoblock pics | Rarkov | Chip Amps | 19 | 17th April 2003 07:37 AM |
| Mini Cresendo for sale | blu_line | Swap Meet | 0 | 26th August 2002 06:17 AM |
