How to increase gain of Quad 34 preamp. - diyAudio
Old 28th August 2014, 09:17 AM   #1
Default How to increase gain of Quad 34 preamp.
Hello
Is there an easy way to increase the gain of the tape input of the Quad 34 preamp, say double.
thyristor44
Old 28th August 2014, 01:27 PM   #2
There are a couple of versions of the Quad 34. Based on the second issue (all grey buttons) R16,R18 need only be replaced by wire links to increase sensitivity from 300mV to 100mV for full rated output. You can easily download the earlier model schematic and go from there if you want that. This change is specified on the schematic, though with a sensitivity of 10x that normally required for digital sources, noise will probably become quite noticeable.
http://www.hifiengine.com/manual_library/quad/34.s
Ian
Old 28th August 2014, 04:12 PM   #3
Thanks Ian I have already done that, the problem is gain with cd player and radio are fine but input from dac is much less and almost has to be on max vol for satisfactory level. Could be I need a better dac as some seem to have a gain control.
Old 28th August 2014, 07:43 PM   #4
Mooly's Avatar
Originally Posted by thyristor44 View Post
Hello
thyristor44
Depends on your definition of easy
Its easy
Cut the print and insert a resistor ( RF on my diagram). 10k to 22k would be a good value. Select R to give as much gain as you want. Gain = (RF + R)/R so using say 15k for RF and 4k7 for R would give a gain of just over 4. Drop R to 1k and you have a gain of 16.
Edit... I've just spotted the input resistors too. If R137/138 are fitted then you have a large attenuator effect. Make sure they are not fitted. You could usefully link out the 39k's in series with the input imo.
Installing and using LTspice. From beginner to advanced.
Old 28th August 2014, 08:33 PM   #5
Nice idea Mooly, unfortunately its a very early 34 and they dont have op amps on tape input, all inputs are switched to one op amp and increasing gain here would increase all gains. I could add op amp to tape input as in your diagram but that is getting quite major for me.
Old 28th August 2014, 09:23 PM   #6
I'd look at increasing the output of the DAC,
can't be hard, couple of resistors probably.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 28th August 2014, 09:57 PM   #7
Originally Posted by sreten View Post
I'd look at increasing the output of the DAC....
Agreed, this would be where to look because any freestanding DAC should be capable of 1V output, like any digital source, and should easily overdrive a 300mV tape input.
Unless it's attenuated in firmware or there are pots or fixed dividers preset for another duty, it must be malfunctioning. I shouldn't think there is a need for a better DAC if there is some output - just that it's output buffer level needs sorting out. If you keep raising preamp gain to compensate for feeble input, you only make matters worse.
Ian
Old 29th August 2014, 11:40 AM   #8
There are no dividers I can see. The outputs from the 9001 go through 33 ohm resistors and the outputs from the 1543 go to 1k resistors to earth also the Vref, 1k to earth.
Marshall AVT 50 preamp gain/distortion increase Voland Tubes / Valves 3 27th November 2010 02:05 PM
Quad 34 preamp tilt pot resistance ? Zigis Analog Line Level 4 8th September 2010 03:13 AM
Quad 520f amplifier and 34 preamp for sale valvusmusicus Swap Meet 0 22nd April 2009 08:54 PM
QUAD 34 help needed lmunasi Solid State 4 8th March 2008 10:32 PM
Quad 34 on blink FM300 Solid State 12 20th March 2005 09:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
