How to match MJL3281A?
Old 14th January 2004, 09:30 PM   #11
azira is offline azira  United States
I assume those values are Ic's... Are you sure the base voltage was fixed and exact?
I think it would be better to measure your base current also because it can vary quite a bit with slight variations in the voltage.
Old 14th January 2004, 09:49 PM   #12
millwood is offline millwood  United States
Account Disabled
Default Re: How to match MJL3281A?
Originally posted by Calebay
I need to match 2 pairs of MJL3281A NPN, for my JLH 15 amps.
Carsten
I question the necessity to match upper and lower transistors in the JLH.
I have done extensive simulation, including real life transistors and "ideal" transistors and I saw no impact from beta-mismatched transistors. You can check it out in the JLH thread.
and I never matched my BJTs for my JLH1969 and they all sound as good as the next one.
Old 15th January 2004, 09:32 AM   #13
Geoff is offline Geoff  United Kingdom
Carsten
I suggest you ignore millwood's comments. It is clearly shown in Table 2 of the original 1969 article that the measured distortion deteriorates significantly as the mismatch between the current gains of the output transistors increases.
Also, I have shown in the thread referred to by millwood that the maximum available output power is reduced if the output transistors are not reasonably well matched.
Matching power transistors using a multimeter hfe test facility is a waste of time. The currents used are far too low for realistic readings. You need to measure the hfe at the collector current that will be used 'in circuit', i.e. your proposed quiescent current. Rod Elliott's transistor tester project - http://sound.westhost.com/project31.htm - can be adapted (simplified) to meet your needs. Alternatively, build your amps and measure the gain of the transistors in the working environment then swap them around to achieve the best match.
Geoff
Old 15th January 2004, 11:18 AM   #14
Account Disabled
Originally posted by Geoff
Carsten
Geoff
I think what ought to be ignored are comments whose author cannot articulate and back up. Quoting the JLH article is helpful but you and JLH did not state the other conditions under which those experiments were taken.
Not to mention that your credibility was seriously shot by those mistakes you made in that very thread.
But i wouldn't be as rude to tell others to ignore your posts, however wrong I might think they are.
Old 15th January 2004, 04:36 PM   #15
Praise! is offline Praise!  Australia
Default matching
Hi there,
Matching of NPN with PNP in push-pull DOES reduce distortion.
For reference, check out MJL21193/MJL21194 data sheets.
The improvement is 10 fold ie an order of magnitude. (open loop)
Don't use multimeter, they are only for small signal transistors
where the test collector current is under 3mA.
Here is an easy way to match: mind you, you will need a large number of your type of BJTs.
Get a precise constant current source IC from National Semi, the LM334Z. set up the resistor needed so that it outputs 1mA precisely. You will also need a voltage source ie power supply.
Set it to the sat voltage. Something like 6V will do. Inject that
1mA into the base, mesure the collector current and the reading
in mA is the Hfe value.
You can get free LM334Z at NSC website if you are commerical.
I don't mind sending you one for free if need be.
Just one comment: The MJL3281A/MJL1302A is out dated.
They are replaced by 2SC5200/2SA1943 which are not only more
linear but also less junction capacitance. (so that the amp is
more stable) I do sell them, matched pairs as well at very
competitive prices. If you do need them, pop me a email!
God Bless
James Yung
Praise! Audio
Old 15th January 2004, 04:46 PM   #16
Default matching
Sorry guys! and Carsten!
I didn't read your first mail properly. I was assuming
NPN / PNP push pull. I can't remember JLH design off head.
Anyhow, the method in my last post is still valid if you want to
measure Hfe.
However, to match NPN with NPN or PNP with PNP, there is
an alternate way: Test their Vbe. Most multimeter has diode
check function which also tells you the forward voltage. So,
just pop the 2 leads across the base and emitter and read
the readings. The range is very narrow. 0.6V - 0.8V depending
on your multimeter test current.
My sincere apology for confusion.
James Yung
Praise! Audio
PS I can match 2SC5200/2SA1943 this way as well.
Old 15th January 2004, 04:50 PM   #17
Red face thread
oh no, i have to say sorry again!!!
Please see my thread, Carsten.
inexpereniced user of diy.com,
James Yung
Praise! Audio
Old 15th January 2004, 05:56 PM   #18
sam9 is offline sam9  United States
sam9's Avatar
I'm inclined to second, in part, Millwood's comment that transistor matching may not be all that critical. While I normally match the small TO-92 transistors that are used in the long tailed pair and in current mirrors, I don't usually bother with the others. Granting that matching all pairs would reduce distortion, the actual measured distortion has been so close to what an earlier simulation suggested as ideal that I suspect the improvement from further matching was less than the resolution my equipment could measure.
Even when I have not bothered to match current mirrors and differential pairs, the results from the amp measured as a completed unit were more than acceptable.
I am most definately NOT from the "THD+N doesn't mater" school, but feel that after a certain number of leading zeros are achieved, additional refinement is a question of design aestheic rather than a auditory benefit. Nonetheless, I fully appreciate the satisfaction that may come to a designer/builder is sqeezing out the last drop of distortion.
Old 15th January 2004, 06:22 PM   #19
I fail completely to see how my credibility was reduced during the recent exchange of views, though if it makes you happy to think it was then please feel free so to do.
I have reviewed all the posts I made in that thread during December and there were no mistakes. There may have been some statements with which you did not agree but, there again, you did not agree with Alex, Thijs and Graham (who expressed similar views to my own) on the topic of the workings of the BJT output stage.
I will leave it to Carsten, and other readers, to decide if they prefer to believe the published results of measurements taken by a highly-regarded designer or yourself.
Old 15th January 2004, 06:50 PM   #20
Account Disabled
I am in no way, shape or form responsible for other's failure to comprehend. Tho. I would rather not pull this thread into a debate about why your view was wrong.
But if it makes you happy to think I was then please feel free so to do.
How to match MJL3281A?Hide this!Advertise here!
Evaluation results: MJL3281A/MJL1302A SPICE Models andy_c Solid State 36 21st October 2008 04:12 PM
MJL4281A vs. MJL3281A...++ Lyra Parts 2 26th November 2004 08:26 AM
mjl3281a vs mjw3281a crippledchicken Parts 6 18th November 2004 01:10 AM
On semi MJL3281A mounting Question Fritz Solid State 6 25th November 2002 10:19 PM
Compare of MJL21193/94 with MJL3281A/1302A sonnya Solid State 12 7th March 2002 07:49 AM
Copyright ©1999-2017 diyAudio
