How to match MJL3281A? - Page 4 - diyAudio
Old 19th January 2004, 01:25 AM   #31
AKSA is offline AKSA  Australia
Christer,
My pleasure, thank you for your input.
Only a few small secrets, nothing to get upset about!
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 24th February 2004, 10:41 AM   #32
MrTransistorm's Avatar
Originally posted by AKSA
I built a simple jig with a current source and a differential amplifier which supplies this current to the transistor under test and sets up an appropriate base drive to the DUT to ensure a prescribed voltage across the transistor with the chosen collector current. The differential pair senses a reference voltage of half the Vcc (I use a 12V gelcel battery), and adjusts the bias on the base of the device under test (DUT) to ensure half the Vcc between collector and emitter. There is a 100R resistor in series with the base of the DUT so you can measure the voltage drop across it, giving the current through into the base by Ohms Law and thus permitting the operator to figure the beta of the DUT from beta = Ic / Ib.
Hugh,
I'm having a mental block, and I can't seem to visualize how it is connected. Could you or someone else draw a schematic?
Thanks.
Dave//
Evaluation results: MJL3281A/MJL1302A SPICE Models andy_c Solid State 36 21st October 2008 04:12 PM
MJL4281A vs. MJL3281A...++ Lyra Parts 2 26th November 2004 08:26 AM
mjl3281a vs mjw3281a crippledchicken Parts 6 18th November 2004 01:10 AM
On semi MJL3281A mounting Question Fritz Solid State 6 25th November 2002 10:19 PM
Compare of MJL21193/94 with MJL3281A/1302A sonnya Solid State 12 7th March 2002 07:49 AM
Copyright 1999-2017 diyAudio
