How do I test an amp for Damping Factor?
Old 13th August 2014, 07:27 PM   #1
shredhead is offline shredhead  United States
shredhead's Avatar
Default How do I test an amp for Damping Factor?
Yeah, I get that damping factor is useless and it's really a matter of output impedance. If I understand correctly, output impedance of an amplifier varies with frequency?
So that would mean that it would affect the frequency response of the amp right?
I'm wondering how you would do an impedance sweep of an amplifier's output. Does anyone know the standard test that determines an amp's DF at a given frequency? Or do these companies just make up numbers?
Old 13th August 2014, 07:44 PM   #2
Mooly's Avatar
Well if you look it up you'll see damping factor is the ratio of the load impedance to the amplifiers output impedance.
So a rough and ready way to estimate... if you set the amp to give (say) 10 volts rms output (with no speakers attached) as measured on a DVM (use something like 400Hz which any DVM should cope with), and then load the amp with a known resistance as a load (say an 8 ohm or 10 ohm resistor of suitable rating) you will see the 10 volts drop a little as measured at the speaker terminals.
If we assume the amp internally is "perfect" as a voltage source then you can work out the damping factor. For example if you measured 10 volts and connecting a 10 ohm gave 9.8 volts then the internal resistance within the amp is dropping 0.2 volts.
The perfect amp is delivering current I of 10/10 (I=V/R) which is 1 amp. The internal resistance is R=V/I which is 0.2/1 = 0.2 ohm. So the ratio 0.2 to 10 is 50 which would be the damping factor.
That is a bit simplistic and there are other ways to measure damping factor more accurately and over a wider frequency range but if you only have a DVM it will get you in the right ballpark
Try the same test at the end of the speaker leads too such that they are in circuit as well and their resistance is included. Now that amplifier with a claimed 500 damping factor isn't so much different to one of only 30 or 40.
Old 13th August 2014, 09:34 PM   #3
jcx is offline jcx  United States
"tug-of-war" with a resistor load, another amp on the other end driven with your test signal
such as a frequency sweep
measure the V a your amp's output
a soundcard is good down to its crosstalk limit for such a test
Old 15th August 2014, 12:37 PM   #4
huseying is offline huseying  Turkey
Send a message via MSN to huseying
Thats a good way of testing amps' damping, i usually use this method but shredhead please keep in mind that the longer the cables wich you use to connect resistor to amp, the more wrong damping value you get , and also to decrease the cable's resistance use tick cable as posible as you can.
My ebay tube store
http://www.ebay.com/usr/hgungor10
Old 15th August 2014, 12:40 PM   #5
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
Mooly, agree with most of your post but not on this. If the voltage drops to 9.8V with a 10 ohms load the Iout is not 1A but 0.98A...
Just to split some hairs
Jan
Advertising is the rattling of a stick inside a swill bucket - George Orwell
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 15th August 2014, 02:07 PM   #6
Mooly's Avatar
Mea culpa The train of thought wandered while typing and wielding Windows on screen calculator.
Old 16th August 2014, 12:55 AM   #7
sgrossklass is offline sgrossklass  Germany
That's how you do it in theory and practice:
Note that you can basically do this with two channels of one stereo amplifier as well, i.e. the resistor goes between R+ and L+, with playback on L and measurement on R. The resistor should be >10x the expected output impedance (current source approximation), but that shouldn't be an issue since you need something in the usual loudspeaker impedance range anyway. Sufficient load handling advised, shouldn't need to be anything too extreme though.
Old 16th August 2014, 06:38 PM   #8
shredhead's Avatar
I want to test a new amp and an old one to see the differences in the 20-40Hz area but for the old one I'm scared that because it doesn't really have much in the area of protection circuits, it might release the magic smoke.
Does anyone here have any experience in doing these 2 kinds of tests to an old quasi-complimentary dinosaur? Would one test be safer than the other?
Old 16th August 2014, 07:58 PM   #9
Mooly's Avatar
Just do the test at a couple of volts and then there is no danger of anything overheating.
If you add a low value resistor (say 0.1 to 0.47) in series with the speakers then you automatically decrease damping factor down to at least 80 with a 0.1 ohm, and to just 17 with a 0.47 ohm. That assumes 8 ohm speakers and a perfect amplifier with a damping factor of zillions.
Try it.
Old 16th August 2014, 11:43 PM   #10
Kiriakos is offline Kiriakos  Greece
Banned
There is no chance getting a good measurement with an multimeter in the range of 400Hz and up to 20k or 40kHz.
This is an area only for modern Oscilloscopes
How do I test an amp for Damping Factor?Hide this!Advertise here!
Pratical amplifier damping factor test for MTM speakers. chlorofille Solid State 4 3rd September 2010 09:37 PM
Damping factor in DIY amp jaya000 Solid State 25 25th September 2008 12:27 PM
What is SI T-Amp DF (damping factor)? skrstic Class D 1 23rd April 2008 10:49 PM
s5electronics tube amp kit damping factor ben106 Tubes / Valves 9 26th September 2007 10:42 AM
Bogen tube amp with variable Damping Factor viatatto Tubes / Valves 0 27th August 2005 12:35 AM
