Smooth out turn-on voltage spike - how? - diyAudio
Old 13th August 2014, 04:05 PM   #1
eboz is offline eboz  United States
Send a message via Yahoo to eboz
Default Smooth out turn-on voltage spike - how?
Wondering what ideas people have for reducing a voltage spike at turn-on. I have a 1n4007 full-wave bridge into CLC (first small C .2uf) filter. 350v transformer and 15H choke, about 30mA load. I have a spike up to over 540v before it settles to about 320v. How can I eliminate, or at least greatly reduce this spike. I've gone through 2 SSHV regs before I went back to this PS design and realized that this spike is killing the reg. D: I know.. idiot right!? I guess one solution could be a TV damper diode, but what other alternatives are there?
-MW
Old 13th August 2014, 08:47 PM   #2
Mihkus is offline Mihkus  Estonia
Mihkus's Avatar
Mains filter?
Old 13th August 2014, 08:56 PM   #3
Actually I have an answer to my own q. If a resistor is placed in series with the choke, then the spike can be sufficiently damped. The spike is due to an LC resonance and not a spike from line AC.
-MW
Old 14th August 2014, 01:05 AM   #4
Maybe a pair of CL-50s on the AC in and a pair on the secondary AC out. They get hot so keep them away from things.....
The stuff you don't know always humbles us.........
Old 14th August 2014, 08:48 AM   #5
Elvee is offline Elvee  Belgium
Elvee's Avatar
You can add an "intelligent" clipper: it will not create additional drops or losses, and it can be made cheap and reliable.
Here is an example.
The first pic is the initial circuit: the peak voltage exceeds 540V before settling to 327V.
Next is the situation when the clipper is connected: the output is clamped to ~337V (the voltage of the zeners string + Vgth).
The clever bit is the resistor R1: it bears most of the dissipation, and relieves the MOS. The dissipation in the MOS (green) never exceeds ~35W, and only for a short time, a few tens of ms. This means that you don't need an actual heatsink: just a small block of aluminum, for thermal inertia.
The dissipation in the resistor (red) reaches 135W, but only for a short time.
A 10W resistor would amply suffice for this job.
After a mere 200ms, the show is over, and no additional power is dissipated anywhere
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Turn-on DC spike tweeter concern? bvan Solid State 10 25th August 2013 07:25 PM
Cause of extreme voltage swing at turn on Arroyo Solid State 0 6th September 2011 09:52 AM
why there is a spike sound output from the speaker when turn off? motbuddy Analog Line Level 7 10th March 2010 05:17 AM
OPT Voltage spike protection with zeners bigwill Tubes / Valves 8 17th July 2009 04:24 AM
Mosfet Class A drive: Low voltage sharp attack Vgs :VS: Smooth gentle Vgs. Brian Guralnick Solid State 9 20th April 2003 02:11 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
