Hafler P1500 power switch replacement help needed - diyAudio
Old 11th August 2014, 05:48 PM   #1
Default Hafler P1500 power switch replacement help needed
I am very glad I found this forum & am looking for some help.
The AC mains switch on my Hafler P1500 has died. It is a SPDT rocker switch with a green led in the button. I have tried to find a direct replacement for this switch with no luck. The closest I came was by contacting eswitch, but the switch I need is a non stock item with a 3000 pc minimum order!
I did get a couple of similar switches from Digi-Key, but am not entirely sure how to connect them as the order of the lugs are different on the switches.
My question is, can I wire up a switch with no illumination, to this amp? I can't find the schematic to determine how that led got power from the amp board. There are 2 wires coming off of the transformer connected to 1 lug of the old switch, and then a black, and a white wire connecting to the other 2 lugs. The black & white wires go to the amp board, and are not labeled as far as I can tell.
I would greatly appreciate any thoughts or advice that may help me get this amp working again. There are no resources available I could find for Hafler service anymore since the company went out of business some years ago.
Thanks very much!
George
Hafler 9505 switch needed nashbap Solid State 0 5th December 2012 08:07 PM
CTF9191/1000 power switch needed Pure_Brew Parts 0 29th August 2011 09:55 AM
Hafler P1500: how to make volume down to zero (∞db)? jackup Solid State 7 18th April 2011 09:28 PM
Hafler 9500 Power Switch partialresponse Solid State 1 22nd October 2009 07:12 PM
Hafler "Trans Nova" P1500 imix500 Solid State 25 5th May 2007 08:58 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
