SlewMaster Builds
SlewMaster Builds
Old 19th June 2017, 10:21 AM   #2151
Harry3 is offline Harry3  Australia
Default Curve tracer
I purchased this inexpensive curve tracer kit. Transistor Curve Tracer adapter Oscilloscopes Plus Power supply UnAssembled Kit | eBay
Surprisingly the cheap meters that allow hfe measurements are close.
Old 21st June 2017, 01:56 AM   #2152
Originally Posted by jwilhelm View Post
It would be interesting to see if the big change came from moving the servo ground or the feedback ground. Is it possible to repeat testing with the servo ground connected to supply ground?
Hi Thimios,
I would be interested in this as well as I cannot do the test myself.
Harry
Old 21st June 2017, 04:51 AM   #2153
thimios is online now thimios  Greece
Originally Posted by Harry3 View Post
Hi Thimios,
Harry
Ok give me some time and i will do this.
Old 21st June 2017, 08:01 AM   #2154
Vrystaat is online now Vrystaat  South Africa
I wonder how many people use the Spooky to drive subs and if they are used for general amplification on normal speakers. I now OS said they have more bass and are better for subs, but they should be good for driving normal speakers ?
ps Thimios, thanks for the experiment !
Jan
Old 21st June 2017, 08:55 PM   #2155
Liliya is offline Liliya  Norway
In my first Slewmaster this things happens when I turn the power down: A very weak tone on a high frequency( I guess around 5kHz) start, but get weaker and weaker. On the power unit there are bleeder mounted, and I feel that the tone die out together with the emting of the power bank. Any idea?
Eivind S
Old 21st June 2017, 11:09 PM   #2156
Default Spooky grounding
Thanks from me as well!
Old 21st June 2017, 11:56 PM   #2157
Hi Jan,
there are many that use the Spooky for their main amp as they like the sound.
OS does as well. I think for his sub he uses the Wolverine but I cannot find the post.
To do a fair comparison we need to sort out the "grounds" for the Spooky.
Old 22nd June 2017, 01:11 AM   #2158
nattawa is offline nattawa  Canada
Eivind S
When the rail voltage goes way down while reservoir caps drain the storage, there could be a moment the front end stages drop out of their designed working conditions far enough, and from that moment on the feed back loop no longer have sufficient phase margin to stay stable. An oscillation would start. That is probably what you heard. This behavior is part of the reasons many speaker protection designs would cut out speakers early at power off, and delay speaker connection at power on.....So that you would not hear it.
Old 22nd June 2017, 03:22 AM   #2159
bimo is offline bimo  Indonesia
bimo's Avatar
I modify Spooky amplifier for 90VDC PSU, the high frequency quality is good. I use slightly different compensation to achieve more slew rate.
#Perkutut#Emprit#GagakHitam#Elang#Pelatuk#Colibri# Blameless100#Blameless150#Blameless1200#AX14Mod#FX 8Mod#AX11Mod#LM1875InvertingWithBuffer#LM3886Inter tingWithBufferAndDCServo#more...
Old 22nd June 2017, 05:09 AM   #2160
If you want you can share your modified version here.
SlewMaster BuildsHide this!Advertise here!
Slewmaster - CFA vs. VFA "Rumble" ostripper Solid State 9828 28th July 2017 07:33 AM
SlewMaster Project Boards jkuetemann Group Buys 830 19th May 2017 08:53 PM
Who builds in UK bbr81 Full Range 16 4th August 2013 07:51 AM
Starter builds Wolfetan44 Solid State 0 4th June 2013 04:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
Copyright ©1999-2017 diyAudio
