DIY 6channel powermixer - diyAudio
Old 5th August 2014, 06:56 PM   #1
dovizci is offline dovizci  Turkey
Default DIY 6channel powermixer
An article distributed by Fransiz gmbh / Winfried Knobloch about a handmade six channel powermixer - at 1989 and was translated to Turkish by Munip ONIZ.
Old 5th August 2014, 07:18 PM   #2
Old 5th August 2014, 07:21 PM   #3
input modul x6 (max)
Old 5th August 2014, 07:22 PM   #4
same image bigger
http://i.onfinite.com/5j8QcffFd.jpg
Old 5th August 2014, 07:36 PM   #5
The pcb - (copper side) of input
Old 5th August 2014, 07:37 PM   #6
Same image bigger
http://i.onfinite.com/jBcL9ffFd.jpg
Old 5th August 2014, 07:42 PM   #7
The schematic of the input board (pre-amp and tone control)
Old 5th August 2014, 07:50 PM   #8
Connection chart
Old 5th August 2014, 07:56 PM   #9
Part list:
Old 5th August 2014, 08:03 PM   #10
Assembly of the Master board (mixer-master volume-level meter)
DIY ultrasonic LP cleaner + DIY cleaning fluid experiment : FAIL! SomeJoe Analogue Source 6 17th November 2013 09:58 AM
Convert DIN-9pin (6channel) to 3xTRS 3.5mm | Noob help! Nexovus PC Based 7 12th November 2012 07:51 PM
diy disco lights? (based on diy rear projection tv idea) dion_lilley Parts 0 4th July 2007 01:34 PM
Wondering if Upcoming DIY design will work with Tubes? Cheap DIY Kits? demon2091tb Tubes / Valves 28 7th December 2005 05:51 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
