About power spec? - diyAudio
Old 2nd August 2014, 01:09 AM   #1
kuer is offline kuer  Canada
Default About power spec?
Rated Power: 40 Hz 20 kHz 8 ohms 80 W/Ch
I just read a reciver's spec above.
Does the "40Hz" means this receiver is not able to handle the frequency below 40Hz? or just an indication to do with power rate?
Thank you very much.
Old 2nd August 2014, 01:14 AM   #2
rayma is online now rayma  United States
Yes, probably it's a power supply limitation, a too small transformer and/or main capacitors.
Old 2nd August 2014, 01:25 AM   #3
Thanks for you reply.
So it still can handle the low end below 40hz, such as 25hz or 30hz bass, but the power output is limited to 80w at the low 40Hz or below.
Can I understand like this?
Old 2nd August 2014, 01:33 AM   #4
Without knowing the model, I'd suspect that the power output is -3dB at 40 Hz, and decreases below that.
Old 2nd August 2014, 02:58 AM   #5
it's marantz rs4021 stereo receiver. please see the pic, I may got confused.
Thanks.
Old 2nd August 2014, 03:03 AM   #6
and the other information.
I need to know if this receiver can output the low frequency low er than 40hz? I saw somebody online said it can't do that low. My speakers go around 30hz.
Specifications
Tuning range: FM, MW
Power output: 80 watts per channel into 8Ω (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.08%
Input sensitivity: 200mV (line)
Signal to noise ratio: 95dB (line)
Dimensions: 440 x 146 x 387mm
Weight: 11.7kg
Accessories: RC4021SR remote control
Year: 2006
Old 2nd August 2014, 03:24 AM   #7
[QUOTE=kuer;4010419]and the other information.
Well, the power supply capacitors are a pair of 8200uF electrolytics, reasonably typical for receivers. What are your speakers?
Old 2nd August 2014, 03:36 AM   #8
Energy rc70 or paradigm 7se mk3, I can't remember the exact low frequency response, around 30hz or a little more.
Only play some music with low volume.
Not sure if you think this receiver can give the full range sounding after you checked this reciver?
Thanks.
UK spec versus US Spec moggi1964 Tubelab 11 7th February 2014 03:42 PM
FS: The ULTIMATE MIL-Spec Power Supply Wire Diogenio Swap Meet 4 17th August 2012 04:30 AM
HV mA Spec on Large RCA Power Xfmr? duganj Tubes / Valves 7 24th August 2010 08:35 PM
Military Spec Power Transformers - For Trade seabass23 Swap Meet 0 10th April 2010 02:45 PM
Power Transformer spec questions. Will it work or burn up? flysig Tubes / Valves 6 18th June 2009 01:13 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
