Compare of MJL21193/94 with MJL3281A/1302A - Page 2 - diyAudio
Old 7th March 2002, 12:40 AM   #11
sonnya is offline sonnya  Denmark
sonnya's Avatar
Hi paul.
I will go looking for audioXpress tomorrow .. I think i know where to get a magazine. I will mail you if can't get my hands on a magazine.
Thanks a lot!!
By the way MJE15032 and MJE15033 have the same curve as MJL2119X.
So another driver is required .. Maybe Toshiba,Zetex,Rohm,philips (Philips get more and more japanese parts!!)..
My favor right know is Zetex... They are easy to get here in denmark, but they only make parts up to around ~3Watt.
Sonny
Old 7th March 2002, 04:08 AM   #12
Sonny,
I really wouldn't spend much time trying to track down the article. The first 3/4s of it is simply a reprise of Self's article on amplifier distortion which is accessable at Self's website. So here is what you're missing -
"Supringly, the output devices do not contribute increased distortion with increased loading- it all comes from the drivers.
There are good SPICE-simulator evidence that this expanation is correct and LSN (Large Signal Nonlinearity) is entirely due to the beta-droop [what an unfortuneate choice of terminology] causing exta current to be drawn from the drivers, degrading their linerarity. Here is the evidence:
- Simulated output stages buit from output transistors modified to have no beta-droop at all (simply by increasing the SPICE model parameter IKF) show no LSN...
-Simulated output devices driven with zero-impedence voltage sources instead of transistor drivers show no LSN. This shows that LSN does not occur in the output transistors themselves, but in the drivers.
- If you look at the output stage distortion as an error voltage between input and output, the double emmitter follower (EF) stage errror is error=(driverVbe + OutputVbe +Re drop)
A simulated EF output stage with the usual drivers shows that of these three terms, it is primatily nonlinerarity in the driver Vbe that increases as the load resestance reduces, while th output Vbe nonlinerarity is hardly changed. The voltage drop across Re is essentially linerar; as it is in series with the load."
Thats about it, until the second part is published.
I do find Self's comment about the inviolate nature of a single transistor driver somewhat specious. Among those who've incorporated Self's findings, AKSA & LC Audio, both have adopted the EF topology (including the speedup cap accross the resistor linking the emmitters of the driver) through the unique approach of actually listening prior to choosing an output topology that incorporates extended beta outputs. In addition to that adoption, LC has chosen to address the current drive limitations of the driver current by using a cascade of 4 emmitter followers for each rail....
http://www.lcaudio.com/temil.htm
Golly, talk about brute force!
I'm certainly not criticizing Self's (or anyone's) simulation approach to design. It is through the use of these powerful tools that the state of the art is advanced. I just don't happen to agree that objective measures should necessarily superceed subjective metrics.
Old 7th March 2002, 07:49 AM   #13
sonnya's Avatar
Hi paul.
Your comment :
"I'm certainly not criticizing Self's (or anyone's) simulation approach to design. It is through the use of these powerful tools that the state of the art is advanced. I just don't happen to agree that objective measures should necessarily superceed subjective metrics."
I agree a lot in this because there is a lot of things we do not know about the human ear.
I only use the sims to get up with something who is not totally wrong in terms of stability,distortion etc.
The rest has to be testet in real life > listning tests.
I am going to work now...
See you in this space later...
Sonny
OnSemi MJL3281A/1302A direct replacement for SK 2SC3856/2SA1492 ? JohnSz Solid State 15 24th November 2005 11:29 PM
MJL4281A vs. MJL3281A...++ Lyra Parts 2 26th November 2004 08:26 AM
mjl3281a vs mjw3281a crippledchicken Parts 6 18th November 2004 01:10 AM
How to match MJL3281A? Calebay Solid State 31 24th February 2004 10:41 AM
On semi MJL3281A mounting Question Fritz Solid State 6 25th November 2002 10:19 PM
Copyright 1999-2017 diyAudio
