100w Mosfet amp
100w Mosfet amp
Old 13th January 2004, 11:54 AM   #1
m60gpmg is offline m60gpmg
Question 100w Mosfet amp
Is this Mosfet amp(see the attached file) a simple good amp?
What do you think about it?
100W 8 Ohm +/-50V
components:
R1: 2,2 Kohm
R2: 47 Kohm
R3: 47 Kohm
R4: 3,9 Kohm
R5: 3,9 Kohm
R6: 1 Kohm
R7: 33 Kohm
R8: 12 Kohm 1 Watt
R9: 100 ohm
R10: 100 ohm
R11: 47 ohm
R12: 100 ohm
R13: 220 ohm trimmer m.o. p.5
R14: 100 ohm
R15: 100 ohm
R16: 100 ohm
R17: 4,7 ohm 2 Watt
(I resistori sono da 1/4 watt 5%
salvo diversa indicazione)
C1: 10 F 50 V elettrolitico rad.
C2: 47 pF ceramico
C3: 47 F 50 V elettrolitico rad.
C4: 6,8 nF ceramico
C5: 33 pF ceramico
C6: 33 pF ceramico
C7: 100 nF 100 V poliestere
C8: 220 F 50 V elettrolitico rad.
C9: 100 nF multistrato
C10: 220 F 50 V elettrolitico rad.
C11: 100 nF multistrato
Old 13th January 2004, 12:25 PM   #2
ratu is offline ratu  Spain
c8,c10 only 220uF!!
At least 4700uF better 22000uf for both chanels
Ratu
Old 13th January 2004, 01:25 PM   #3
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
100w Mosfet amp
That is the 'industry standard' MOSFET amp as designed by Hitachi when MOSFETs first became readily available. It has been cloned a thousand times, both commercially and DIY. It performs well, but there are improvements/better alternatives available nowadays.
Old 13th January 2004, 03:53 PM   #4
Did it Himself
100w Mosfet amp
Default no, ratu!
220uF is the correct value as these caps are only for local/close decoupling. PSU smoothing caps are to be used in addition and these should be like you said.
Old 13th January 2004, 09:21 PM   #5
Thanks for all the answer
D.N.
Old 14th January 2004, 05:39 AM   #6
palesha is offline palesha  India
richie00boy said
"That is the 'industry standard' MOSFET amp as designed by Hitachi when MOSFETs first became readily available. It has been cloned a thousand times, both commercially and DIY. It performs well, but there are improvements/better alternatives available nowadays."
We r intersted in this type of schematics and more info.
MP
Old 14th January 2004, 05:55 AM   #7
Cybergent is offline Cybergent  Germany
MP
If you google for "FET amplifier circuit" or similar terms you get plenty of those and similar schematics. Also here in the forum you can find several examples.
Old 14th January 2004, 06:32 AM   #8
Default richieboy
Ok! if its only for decoupling, remember to put it as close as posible to te power mosfets.
Ratu
Old 14th January 2004, 10:02 AM   #9
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
100w Mosfet amp
Like this one
http://www.diyaudio.com/forums/showt...626&highlight=
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 14th January 2004, 10:21 AM   #10
Default T1,T2
It is very iportant that you buy many mirror transistors(10 or 20 units of T1 and T2) and measure the hfe of each one, try both which have the same hfe and in the case that you have many, try the maximum value of hfe.
This is aplicable for all mirror transistors!
RATU
100w Mosfet ampHide this!Advertise here!
Maplin 100W mosfet amplifier - power supply problem HBrunt Solid State 32 3rd December 2013 07:11 AM
100w Stk nbcd Chip Amps 14 30th September 2009 01:36 PM
12v dc to dc 100w psu razordave123 Power Supplies 13 7th February 2006 04:29 PM
Evolve Amps 100W+100W Stuff 4 Sale WALTER BURKHARD Swap Meet 4 8th June 2005 10:57 AM
100W amp Vivek Solid State 13 23rd December 2001 07:57 PM
Copyright ©1999-2017 diyAudio
