Transistor Replacement Question - diyAudio
Old 25th July 2014, 02:42 PM   #1
Default Transistor Replacement Question
I have an older teac ag-v8060 receiver I got at goodwill yesterday. Can I replace the output transistors with other ones when all the specs have higher ratings except the continuos current? (1.5 vs. 4) Only reason I ask is because the max voltage is 150V higher, so at a lower voltage it can maybe take more current.
2SC4468 to MJL4281A
If not, please suggest better transistors because the ones in there are Sanken.....can't be too great.
Old 25th July 2014, 06:41 PM   #2
Originally Posted by ivandezande View Post
2SC4468 to MJL4281A
MJL has somewhat higher fT (good) but more than twice the Cob (not so good). I'd say it should usually work in an EF output stage, not sure about CFP. Also note TO-3P vs. TO-264.
Manufacturers wouldn't get away with underspec'd output stages nearly as well if (genuine) Sanken transistors weren't any good. They're not exactly too cheap.
Old 25th July 2014, 06:53 PM   #3
ok thank you. The cases are about the same I compared the measurements. I will probably stick with the originals, I had no idea they were decent!
Old 25th July 2014, 07:07 PM   #4
KatieandDad's Avatar
Is the original unit faulty ?
Old 25th July 2014, 08:16 PM   #5
no it is not. just thinking about upgrades.
Old 25th July 2014, 09:46 PM   #6
llwhtt is offline llwhtt  United States
If it ain't broke don't fix it.
Craig
Old 28th July 2014, 01:04 AM   #7
actually, there is a fair amount of hiss on them. like bad.
had to replace the psu caps they were bulging.
Old 28th July 2014, 02:33 AM   #8
Replacing all the electrolytic capacitors in it is your best bet.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 28th July 2014, 02:47 AM   #9
thanks, do you think the 4558 op amps could be adding to it too?
Old 28th July 2014, 11:33 AM   #10
.................all the specs have higher ratings except the continuos current? (1.5 vs. 4) Only reason I ask is because the max voltage is 150V higher, so at a lower voltage it can maybe take more current.
2SC4468 to MJL4281A...............
"so at a lower voltage it can maybe take more current."
This does not follow.
The published SOA curve will tell you.
Compare the currents at your rail voltage to see what difference the SOA makes to your choices.
regards Andrew T.
Transistor replacement grandville45 Parts 30 1st April 2010 05:50 PM
Question about transistor replacement CKeeler Solid State 5 12th December 2009 04:09 PM
Transistor Replacement portlandlay Solid State 26 14th December 2005 07:46 PM
Transistor replacement Mlaen Solid State 3 18th February 2005 11:00 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
