any ideas for replacing the steel (cheap!) jumpers connecting pre to power in nad amp
Old 13th January 2004, 06:39 AM   #1
nad freak is offline nad freak  India
Post any ideas for replacing the steel (cheap!) jumpers connecting pre to power in nad amp
hi there,
nad amps have cheap steel jumpers connecting preamp out to power amp in at the back. thinking of replacing them but with what? silver? copper? any ideas out there as to what i can do to replace them and improve performance of my system?
Old 18th July 2004, 02:29 AM   #2
Mat is offline Mat  Malaysia
just like any other pre to power, you can replace the metal connector on your integrated amp with an interconnect cable..
if you know how to terminate an interconnect cable, you can started by using an ordinary inexpensive microphone cable. use about 4 inches per side. even this cable would normally gives better results than the original metal connector. of course if you're willing to spend more...you will get better results.
Old 18th July 2004, 02:59 AM   #3
sam9 is offline sam9  United States
sam9's Avatar
I would be willing to bet they are not steel, but knicle plated brass. Not all bright, shiny non-yellow metals are steel.
If you cut them in half you would know for sure.
BTW I had a NAD reciever about 15-20 years ago and put some kind of processor in that loop. I took the ocassion to cut one of the jumpers. The inner metal was somekind of yellowish metal. Anyway, I also tried to using the interconnect just to replace the jumpers. I had much more accute hearing back then, and frankly, could hear no difference.
Old 18th July 2004, 03:04 AM   #4
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
when i had my nad 3240 PE I believe and my nad 2200 i opened up the pre amp and did somehard wire soldering for the jumpers.. i didnt like how the others acted like areal antenna.
Old 18th July 2004, 03:38 AM   #5
eLarson is offline eLarson  United States
eLarson's Avatar
I had used a half-meter pair of AudioQuest Topaz to good effect. A half-meter pair of just about anything would work fine, I reckon.
If you're going to roll yer own, you can make them whatever length you want, of course.
Would a woodchuck bother to chuck MDF?
Old 18th July 2004, 03:41 AM   #6
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
speaking of audioquest, they actually make a specific jumper just for that purpose...
found here:
http://www.hcmaudio.com/comp.asp?compID=670
any ideas for replacing the steel (cheap!) jumpers connecting pre to power in nad ampHide this!Advertise here!
Replacing circuit board jumpers tom1356 Digital Source 1 29th April 2007 12:10 AM
good cheap first project ideas saramac Full Range 21 23rd November 2004 09:49 PM
Any good, cheap ideas? sauuuuuce Solid State 11 2nd August 2004 02:34 PM
Anyone have any ideas for cheap DIY satellite/sub system? mikejz84 Multi-Way 8 8th September 2003 03:00 AM
cheap project ideas theChris Parts 0 22nd March 2003 02:36 AM
