output transistor topology question - diyAudio
Old 22nd July 2014, 11:16 PM   #1
lazzer408's Avatar
Default output transistor topology question
In a push-pull output stage, what's the difference between the pair being one NPN and one PNP vs. both being NPN?
Am I correct in saying the latter is "quasi complementary"?
Old 22nd July 2014, 11:25 PM   #2
nigelwright7557's Avatar
NPN/PNP is complimentary.
NPN/NPN or PNP/PNP is quasi complimentary.
Old 22nd July 2014, 11:28 PM   #3
lazzer408's Avatar
Acoustically, what's the difference? What are the pros/cons to complimentary vs. quasi complimentary?
Old 22nd July 2014, 11:31 PM   #4
There should be little if no difference in sound, at least that's what I found.
Quasi comes from the days of few PNP power transistors.
I have found in my designs the quasi was a little harder to bias as it wasn't quite as stable due to gain in the lower driver.
I also found oscillation troubles again with the lower driver. I fixed this with a BC capacitor on the lower driver.
Old 23rd July 2014, 02:07 AM   #5
A good article about output stage topology from Rod Elliot click here.
Old 23rd July 2014, 03:54 AM   #6
lazzer408's Avatar
I'm contemplating these China kit amplifiers and trying to find what makes one different then another.
Old 23rd July 2014, 04:00 AM   #7
jcx is offline jcx  United States
Self's Audio Power Amplifier Design Handbook, later editions gets you up to speed on "conventional " audio design pretty quick - Cordell too but he spends more time on Mosfet outputs
I believe I've seen Duncan's and Sloan's much older books online
Can bias transistor mount on top(body) of output transistor?? Leolabs Solid State 23 16th February 2008 12:35 AM
Output transistor question ThSpeakerDude88 Solid State 15 29th July 2005 10:25 PM
Aleph output topology question mpmarino Pass Labs 3 15th February 2005 06:06 PM
output transistor biasing question? crippledchicken Solid State 7 16th April 2004 12:48 AM
New P-P output topology? the Elliptron smoking-amp Tubes / Valves 14 16th February 2002 08:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
