Technics SA 626 blowing fuse before transformer Technics SA 626 blowing fuse before transformer - diyAudio
Old 22nd July 2014, 01:43 PM   #1
rfitts46 is offline rfitts46  United States
Default Technics SA 626 blowing fuse before transformer
Blows F1 (T4A) fuse. Measured resistance of rectifier diodes in circuit and they seem to be okay. Got a large reading one way...increasing with time and a neg small reading the opposite way decreasing with time. I am thinking of disconnecting the AC connections from the rectifier and confirm that the transformer primary is good. I think I measured some resistance on the primary...small 1 ohm or so but still not open. Should I put a good fuse in it and use a light bulb on the input? Should tell me if it is a soft or hard short?
Picked this off of another thread. Check resistance between the main plug and the chassis, and between both pins of that AC plug.
What results should I look for in the above test?
Old 22nd July 2014, 01:47 PM   #2
Default 110 vac versus 120 vac switch
The two times the unit was powered up with a fuse in it the switch on the back was set 110 vac. I have switched it to 120 vac but I assume this would not cause Blows F1 (T4A) fuse to blow.
Old 22nd July 2014, 02:56 PM   #3
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
The first thing to do is disconnect the rectifier ac input. With the transformer in a no load situation, feed the transformer through a 100Watt incandescent mains lamp. The lamp should go out. If it stays bright, replace the transformer as it has a damaged primary winding that is usually caused by poor/intermittant mains supply. Transformers don't like to be switched on!
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 22nd July 2014, 03:47 PM   #4
Enzo is offline Enzo  United States
Step back and look at the larger picture. Most common fuse blower in an amp is shorted output transistors - how are yours? You already checked for shorted rectifier diodes, but you used resistance. Use the diode function of your meter to test. A diode does not need to be shorted to read super low at its junction.
Old 23rd July 2014, 12:47 AM   #5
cut the transformer secondary wires that supply the rectifier. Using a dim light bulb tester powered up the unit and it was ok. The light bulb stayed Dim the whole time and I was able to measure 63 vac on the secondary that supplies the rectifier. a lot of the switch indicators on the front panel work.
Old 23rd July 2014, 12:52 AM   #6
This receiver was purchased overseas so on the back there is a switch that can be set for 240/220/120/110. The first two times it was powered up it was set to 110. Since then it has been switched to 120. Is this a possibility for blowing the fuse?
Should I reconnect the secondary lines to the rectifier and bring it up on the DLB tester?
Old 23rd July 2014, 01:16 AM   #7
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Its a matter of disconnecting each stage until the mains lamp stays on.
Disconnect secondary to rectifier. Test.
Reconnect. Disconnect output from smoothing to pcb. Test.
If you get to this point it is probably output transistors blown.
Replace them but still test using lamp in series with mains.
If the lamp comes on then something in the driver, VAS or LTP stage will be at fault.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 23rd July 2014, 01:59 AM   #8
kevinkr's Avatar
Selecting the 110V position over the 120V position is very unlikely to cause damage - if OTOH it is actually 100V (for Japan) it is possible that something got damaged.
Disconnect the power amplifiers from the supply capacitors and check for shorts from each rail to the outputs.
Check the diodes out of circuit if possible as well.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 23rd July 2014, 12:53 PM   #9
thanks for the support!
Disconnect filter capacitors (smoothing caps)C701 and C702 56V 12000 uF the big PS caps?
To disconnect from supplying the non filtered +48VDC and -48VDC to the amplifier output stage wouldn't the circuitry on the printed circuit board have to be cut?
Old 23rd July 2014, 12:55 PM   #10
Kevin, I wasn't thinking of damage as much as blowing the main 4A fuse in front of the transformer.
I want to rule this out as a possible cause of fuse blowing. The only other way is to reconnect secondary and see what happens to the mains lamp (DLB).
Technics SA 626 blowing fuse before transformerHide this!Advertise here!
SA-W2500 Sub blowing fuse 2dbit Solid State 14 27th February 2013 05:33 AM
Technics 1210 Mk2 Internal Fuse keeps blowing dunksterp Analogue Source 5 21st October 2011 06:52 PM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 10:39 AM
Transformer fuse nuisance blowing halfgaar Parts 16 10th September 2006 10:53 PM
Copyright ©1999-2017 diyAudio
