Technics SA 626 blowing fuse before transformer
Old 23rd July 2014, 03:13 PM   #11
rfitts46 is offline rfitts46  United States
Enzo, will measure diode bridge using diode test of DMM since the secondary AC connections are removed.
Old 23rd July 2014, 04:13 PM   #12
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Remove the wires that feed the + - 48v rectifier. Test again.
Blowing a 4A fuse in the primary is a substantial short circuit! Disconnecting the transformers secondary windings will rule out either the rest or the transformer.
Keep it simple and take photographs on your mobile phone to aid rebuilding.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 23rd July 2014, 04:18 PM   #13
Jon, the T1 secondary wires that supply the AC to the rectifier were removed and DLB good. Transformer is good.
Are you saying to remove the DC output from rectifier and test again? This would tell me the rectifier is good.
Old 24th July 2014, 01:34 AM   #14
confirmed tonight pair of output devices and a pre driver on one side of the amp are blown. confirmed by finding shorts between pairs of leads on each of the devices.
Old 24th July 2014, 01:45 AM   #15
kevinkr's Avatar
Good to know, but a bummer.. I imagine finding replacement transistors for this amp could be a little tricky.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 24th July 2014, 03:05 AM   #16
2SB755 and 2SD845 Toshiba does anyone have a set they want to sell?
Old 24th July 2014, 10:00 AM   #17
Welcome is offline Welcome  France
Welcome's Avatar
Nobody does, and if you find them they will be fake. You'll have to find modern equivalents. That is, different product number, different (but compatible) specs. Start by looking at the datasheet and case type, then look for new transistors with the same case. You're bound to find something similar.
Old 24th July 2014, 10:21 AM   #18
2SB755 TRANSISTOR (JR 2SBB1) | eBay
2SD845 Original Toshiba Transistor D845 BRAND NEW FAST DISP x 1 pieces Uk Seller | eBay
I would use a pair of T03p transistors of a similar grade and drill and tap the centre of each mount.
There are still plenty about.
Old 24th July 2014, 10:23 AM   #19
Have you tried an established Technics/Panasonic Repair Agent in your area, for spares?
Old 24th July 2014, 10:24 AM   #20
Sorry but I could see no reference to you having removed the secondary load.
Technics SA 626 blowing fuse before transformerHide this!Advertise here!
SA-W2500 Sub blowing fuse 2dbit Solid State 14 27th February 2013 06:33 AM
Technics 1210 Mk2 Internal Fuse keeps blowing dunksterp Analogue Source 5 21st October 2011 07:52 PM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 11:39 AM
Transformer fuse nuisance blowing halfgaar Parts 16 10th September 2006 11:53 PM
