Technics SA 626 blowing fuse before transformer - Page 3 - diyAudio
Old 24th July 2014, 02:51 PM   #21
Default Sanken 2SA1295/2SC3264
I am heading in the direction of buying a pair of Sanken 2SA1295($6.55)/2SC3264($6.80) from Digikey.
Too many fakes of the existing Toshiba being offered along with the NTE products. The $2 and $3 NTE chips from China can not be genuine.
I know this unit is not worth the investment but I look at it as a learning project.
Any thoughts or comments?
Old 24th July 2014, 07:56 PM   #22
Actually found them cheaper at Newark. $4.54 and $3.90.
Old 25th July 2014, 10:32 AM   #23
removed output IC's on one channel. Reconnected secondary, Using DLB powered amp up and the bulb glowed brightly and then decreased. Relay clicks.The bulb still seems to glow substantially. The amp did power up without blowing a fuse. Connected speaker up to see if any evidence of output on the one good channel and no evidence.
Old 25th July 2014, 11:47 AM   #24
Test the assembly in simple stages.
Power on via Mains Bulb Tester until you haved proved that all modules and all wiring is all operating correctly.
First test the transformer alone.
Then test the transformer plus rectifier.
Then test the transformer plus rectifier plus one pair of smoothing capacitors. Use a pair of small (around 100uF to 470uF) electrolytics with a voltage rating above what the previous test showed as output voltage.
Then test the transformer plus rectifier plus original smoothing capacitors.
Then test the transformer plus rectifier plus original smoothing capacitors plus one amplifier.
Remove that amplifier and repeat the test with the other amplifier.
Then test the transformer plus rectifier plus original smoothing capacitors plus both amplifiers.
Then test the transformer plus rectifier plus original smoothing capacitors plus both amplifiers plus one speaker or dummy load.
Then test the transformer plus rectifier plus original smoothing capacitors plus both amplifiers plus both speakers or dummy loads.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 25th July 2014, 01:01 PM   #25
AndrewT, This receiver has one integrated regulator, driver, and power circuit board. The only hard wiring that can be removed is the AC from the transformer secondary.
I have confirmed the transformer secondary for the amplifier section is not shorted or open by removing load upstream. Cut wires.
Then removed output IC's(one PNP and one NPN, MT200 case) on one channel that had hard short emitter to collector, removed hard short, the receiver can now be powered on with DLB in place. The dimness of the bulb after capacitor charge up makes me suspicious of a soft short?
Now that the side that had the hard short is powered I can measure voltage on rails, measure voltage at transistor bases, etc?
To test section by section I assume the transistor upstream must be unsoldered and removed from the board?
Old 27th July 2014, 06:35 PM   #26
tested the transistor rail voltages they are ok. checked out the two transistors one stage back from the shorted output IC's and they check ok. ordered a pair of the Sanken transistors from Newark.
did power the receiver with out the output IC's on one side installed using straight 120 VAC without the DLB in place and it was ok.
Old 28th July 2014, 01:02 PM   #27
I am assuming without the output IC's in place on one channel that it goes in to protect mode?
Can anyone help describe how the self protect mode works?
I see IC801 with nine inputs does the function.
There is a large relay 801 near IC801 that is clicking. It appears it opens or closes the final stage output.
The 48VDC rail voltages are present.
There are two inputs on IC801 monitoring output of final stage...without the output IC's on one channel in place, the IC is not happy?
File Type: png technics sa 626 schematic protect circuit.png (620.1 KB, 50 views)
Old 28th July 2014, 09:32 PM   #28
you can measure the voltage before the relay contacts.
A high DC here should be detected and prevent the relay closing.
regards Andrew T.
Old 1st August 2014, 11:41 AM   #29
replaced the output IC'S and the unit is up and running. I used the Sanken IC's. I will have to comment at a later date when I get time to listen well to see if there is any difference in the sound of the original ICS on one channel and the replacement IC's on the other.
the volume level indicators I'm not working so I will fool with that next. Any Ideas?
Old 5th August 2014, 10:27 AM   #30
The volume range indicator, as it is called on the schematic, is a plastic sheet that rotates using the volume motor shaft. It is a belt. Inside the housing is a #44 6v .25 amp bulb. The bulb was blown waiting for a replacement. It was difficult to get to but will post images of this contraption.
SA-W2500 Sub blowing fuse 2dbit Solid State 14 27th February 2013 05:33 AM
Technics 1210 Mk2 Internal Fuse keeps blowing dunksterp Analogue Source 5 21st October 2011 06:52 PM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 10:39 AM
Transformer fuse nuisance blowing halfgaar Parts 16 10th September 2006 10:53 PM
Copyright 1999-2017 diyAudio
