Freezing electronics to kill bedbugs?
Old 23rd July 2014, 02:53 PM   #21
jcx is online now jcx  United States
if it has polystyrene capacitors they will not be the same after - they have a very low heat distortion temp
Old 23rd July 2014, 02:55 PM   #22
R.I.P.
Would a microwave oven damage any of the electronics.
Should completely frazzle all bugs.
regards Andrew T.
Old 23rd July 2014, 03:35 PM   #23
Mooly's Avatar
What about all the metal bits. It would be an oven full of sparks.
Old 23rd July 2014, 04:01 PM   #24
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Use an oven thermometer to ensure the oven is not too hot. Preheat it for at least 30 minutes to ensure a stable temperature. Leave in for two hours.
planet10 needs your help:
Let's help Ruth and Dave
Old 23rd July 2014, 04:57 PM   #25
JimT is offline JimT  Canada
Regarding bedbugs, Wikipedia says
"An hour at a temperature of 45 C (113 F) or over, or two hours at less than −17 C (1 F) will kill them"
45 C should not harm your electronics and if you have a chest freezer, it is -20 C. Your fridge freezer may not go that low. I have bagged things and put them in the freezer to kill bugs. My fly fishing friends collect road kills for the fur and feathers and bag them and put these in the freezer.
But first google "red mite" and look at images. Mites are very common and nothing to worry about.
Jim
Old 23rd July 2014, 08:05 PM   #26
Welcome is offline Welcome  France
Welcome's Avatar
People like to put bed bug-ridden stuff in saunas. Apparently works well.
Do you have a sauna?
Old 24th July 2014, 03:07 AM   #27
Hogwild is offline Hogwild  Canada
Hi everyone:
I took the receiver in question and tested it outside on my back patio. Output caps had leaked all over the place. Several resistors were fried. It was not worth repairing.
I just took the heatsink/heatpipe and the transformer out of it for future projects. The rest is going in the garbage.
Thanks for all your suggestions. I didn't know it was such a heated <bad pun> topic.
Old 24th July 2014, 03:22 AM   #28
woody is offline woody
Just to be safe drink plenty of beer. It seems bed bugs don't like people with alcohol in there blood stream. Bed Bugs Avoid Blood With Higher Alcohol Content, Study Suggests
Old 24th July 2014, 08:59 AM   #29
Welcome's Avatar
Just for future reference:
1. It doesn't have output capacitors, few amps made after the early 70's do. Those were the main power supply caps. One for each voltage rail.
2. They hadn't leaked, they were glued to the PCB to prevent shipping damage. This is standard practice and will be found in most amps with PCB mounted big caps.
Freezing electronics to kill bedbugs?Hide this!Advertise here!
bluray freezing problems old and newer models KTnC Everything Else 2 19th May 2014 10:12 PM
ESL electronics 101 for the electronics challenged markusA Planars & Exotics 12 29th April 2011 05:19 PM
Freezing Points Of Gelatine And Other Additives In Water kelticwizard The Lounge 41 18th October 2006 03:44 AM
problems with forum freezing IE 6 Bikeman Everything Else 21 1st February 2003 01:36 PM
My Aleph is freezing protos Pass Labs 27 1st August 2002 01:43 AM
