"Mysterious" wire in Krell KSA-50MkII - Page 4 - diyAudio
Old 24th July 2014, 02:51 PM   #31
IT could be a switch for Btl Mode Operation. This would explain only one wire from left Output via a resistor and a switch to the right input
Old 25th July 2014, 10:34 AM   #32
This sounds like the only reasonable explanation! If it had something to do with grounding or feedback then the switch would've been a bit pointless.
To be honest I never knew that KSA could actually be bridged as Krell always had separate monoblock amps - the KMA's.
Old 30th July 2014, 12:16 PM   #33
So now when the wire mystery is solved, can anyone tell me what to replace the old ROE's in the negative feedback loop with?
Building "The Wire AMP" Class A/AB Power Amplifier" wirewiggler Solid State 13 24th January 2015 01:22 PM
"WTB" "The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral enantra Swap Meet 3 23rd December 2012 07:36 PM
Krell S300i Integrated Amp "Made in China" which Factory? tiefbassuebertr Solid State 10 29th October 2011 10:17 AM
Need help to build "Krell KSA-50" space2000 Solid State 12 7th August 2008 02:53 PM
Any thoughts on these mysterious OEM 8" woofers? Spasticteapot Subwoofers 4 21st January 2007 01:25 AM
Copyright 1999-2017 diyAudio
