"Mysterious" wire in Krell KSA-50MkII
Old 23rd July 2014, 02:30 AM   #21
rayma is offline rayma  United States
Originally Posted by LineSource View Post
PERHAPS: A past owner added this switch with the yellow wire and another feedback resistor as a way of setting two different amplifier gains .... two different R8/R9 ratios. i.e. for ONE CHANNEL the switch selects between (a) one resistor = R8; or (b) two resistors in series(or parallel) = R8. This would allow passive Xover circuit bi-amping with different gain for the woofer than for the mid-tweet.
Now that makes some sense. What are the resistor values?
Old 23rd July 2014, 08:04 AM   #22
czolgista778 is offline czolgista778  Netherlands
This Sunday I went to Church and prayed upon your yellow wire.
God told me that Satan is in that yellow wire!
If you fall to temptation and turn the rear switch, Satan will destroy your speakers!!
If you want your speakers free from Satan, you must perform an Exorcism and remove the yellow wire and restore both channels to the standard wiring+feedback. Never touch Satan's switch!!
Can I get an AMEN!
I have seen several Krell KSA50 and KSA100 amps. None had your rear "switch". Your pictures do not show enough details around the switch to trace the circuit.
It seems that only the Mk2 version (fan under the cooling tower and with very thick copper wiring) had the switch on the back:
Old 23rd July 2014, 08:23 AM   #23
godfrey is offline godfrey  South Africa
If there's a switch on the back, I'd expect there to be something about it in the user manual.
Old 23rd July 2014, 08:36 AM   #24
The manuals aren't available anywhere
Old 23rd July 2014, 12:15 PM   #25
PhilippeS is offline PhilippeS  Switzerland
the resitor value is 22K
File Type: pdf krell_ksa-50-mkii_esoteric_dual_mono_classa_pa_sm.pdf (339.6 KB, 78 views)
Old 23rd July 2014, 12:17 PM   #26
Yes, I already have the circuit diagram.
I'm starting to wonder if this isn't a kind of bridge switch
Old 23rd July 2014, 02:14 PM   #27
LineSource is offline LineSource  United States
LineSource's Avatar
Attached: 1-resistor Bridged Amp Topology.
Most bridged amps include an inverting buffer on one input.
Old 23rd July 2014, 02:39 PM   #28
This makes sense. Now we know.
Old 23rd July 2014, 04:35 PM   #29
TheHarbinger is offline TheHarbinger  United States
I want one of these! Where'd you find it and what's it called?
Old 24th July 2014, 05:38 AM   #30
It's called : "Armageddon USB Hub"
Google it !
Philippe
"Mysterious" wire in Krell KSA-50MkIIHide this!Advertise here!
Building "The Wire AMP" Class A/AB Power Amplifier" wirewiggler Solid State 13 24th January 2015 12:22 PM
"WTB" "The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral enantra Swap Meet 3 23rd December 2012 06:36 PM
Krell S300i Integrated Amp "Made in China" which Factory? tiefbassuebertr Solid State 10 29th October 2011 09:17 AM
Need help to build "Krell KSA-50" space2000 Solid State 12 7th August 2008 01:53 PM
Any thoughts on these mysterious OEM 8" woofers? Spasticteapot Subwoofers 4 21st January 2007 12:25 AM
