DC at output and weird voltages - diyAudio
Old 20th July 2014, 06:20 PM   #1
Default DC at output and weird voltages
hi all,
I just finished a P3A and I'm testing it before connecting the speakers.I'm testing with a 12V transformer which gives 20VDC to the amp.
I found two problems:
1) I have 3.5 VDC between output and GRD, which is pretty scary.
2) If I leave the amp plugged in for say 30 seconds, the difference in voltage between + and GRD increases, while the difference in voltage between - and GRD decreases. So far I reached a 15VDC between + and GRD, and a 5VDC betwenn - and GRD.
So far I checked the resitors and they're fine. What do you think the problem could be? E.g. is the different in voltages for +/GRD and -/GRD an indicator of a specific problem?
AC
Old 20th July 2014, 06:27 PM   #2
Frank Berry's Avatar
Load the output of the amplifier with a resistor. 10 ohms would be a good value.
Frank
Old 20th July 2014, 07:09 PM   #3
Art M is offline Art M  United States
You need 2 supply voltages +20VDC and -20VDC.
You seem to be trying to run the amplifier with a single supply ?
Old 20th July 2014, 07:50 PM   #4
@Art M:
Sorry, let me rephrase.
I have +,GRD,-. With my transformer, I expect a +10,0,-10 VDC configuration on the amp.
And as I switch on the amp, that's what I've got.
But if I wait a few seconds, the voltages begin to shift towards a +15,GRD,-5 configuration.
@Frank Berry:
Isn't it so that you should check the VDC without the load? And that this should be in the order of mV?
Old 20th July 2014, 09:07 PM   #5
ok problem solved. transistor mounted backwards
Old 21st July 2014, 12:59 PM   #6
east electronics's Avatar
will the P3a work properly with such low voltage ? i think not
i am missing something here ?
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 21st July 2014, 01:00 PM   #7
Frank ? 10R load with 3.5 v in the output ? make the math ...Kaboum
Old 21st July 2014, 03:25 PM   #8
hi,
no it won't work with 12V. But I was performing a smoke test.
I had the driver transistors mounted backwards so..
Btw, once I reversed them I get 150mV on the output. Which is quite a lot in my opinion, so..
I still have to set the bias, would that help lowering the DC at the output? (I used max resistance in the trim, for the smoke test)
AC
Old 21st July 2014, 04:39 PM   #9
expect the Dc offset to be expected at such a low rail voltage
Increase rails and i expect the offset to drop gradually
No load conditions no signal
Kind regards
Sakis
Old 21st July 2014, 06:37 PM   #10
hi,
I connected the planned PSU (24-0-24, bringing 33,0,-33V to the amp).
The DC offset is now 90mV right, 120 mV left.
Still quite high I think.
Would this damage my 8ohm speakers?
weird DC offset at HF driving passive filter Stefanoo Solid State 17 8th January 2012 07:56 PM
how do I lover dc voltages robertguerrieri Power Supplies 18 23rd February 2011 01:18 PM
AC to DC converter with selectable voltages? Audiophilenoob Power Supplies 28 11th October 2005 04:51 PM
AC to DC converter with selectable voltages? Audiophilenoob Multi-Way 0 9th October 2005 01:33 AM
Taking a chance here - problem with DC voltages arnoldc Solid State 5 21st September 2004 11:23 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
