4-layer PCB, 2 voltages, ground ??
Old 12th January 2004, 10:38 PM   #1
cadmaniac is offline cadmaniac  United States
Default 4-layer PCB, 2 voltages, ground ??
I'd like to put (mono) amp & crossover on the same PCB, and can get 4-layer boards made. Crossover uses +/-12V (regulated); Amp PSU will have a separate bridge for each (25V) rail. My idea is to use one internal layer for 0V (shared by both supplies), and the other for signal Ground. Will this work?
4-layer PCB, 2 voltages, ground ??Hide this!Advertise here!
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 4 18th March 2014 09:42 PM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
Constrained layer damping / thin metal / fibreglass layer RobWells Multi-Way 3 6th August 2007 05:50 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
How to through plate DIY 2-layer PCB sam9 Parts 7 12th February 2003 07:43 PM
