What is the best power for an audio amplifier?
Old 14th July 2014, 02:46 PM   #1
jazzclassics is offline jazzclassics
Default What is the best power for an audio amplifier?
What is the best power for an audio amplifier? This is a topic been discussed by many for a long time. Half centry ago, amps with 10-20W were considered enough for usual home use. In the beginning of 70s, most of the hi-fi amps had about a few tens of watts, but by the end of the decade, it increased to around 100W. From 80s to 90s, the pace of such a power increase started to slow down. Most of the amps we use today are still 100W to 200W.
It is interesting that the power of Hi-Fi amps has been folded from 60s to 80s. But why the trend did not continue from 80s to the following decades?
Do you think an amp with 100W to 200W enough for your use?
Old 14th July 2014, 03:03 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
More than enough given descent speakers. In the past most loudspeakers were rated at 100dB or more, (Goodmans/Wharfedate Ditton etc), now they seem around 88dB. Hence power requirement?
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 14th July 2014, 03:47 PM   #3
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I used to use 225WRMS on a mobile disco so a couple of hundred watts is more than enough for home use.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 14th July 2014, 03:53 PM   #4
On Hiatus
SY's Avatar
42.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 14th July 2014, 04:07 PM   #5
RAndyB is offline RAndyB  United Kingdom
Default What music do you listen to?
This post comes from Great Britain and applies to the European music tradition.
Until the advent of recordings and amplifiers, the loudest music that most people would have heard was that of an organ and choir in a large church or cathedral.
Try listening to a recital, concert or choral worship in such a place to give your ears a workout.
Most organists cannot resist pulling out all the stops at some point (loudest). If you are lucky then you will hear a 32 ft diapason, with nothing coupled, in the pedals below quiet chords in the manual(s) (lowest); and a 2ft flute stop on the solo manual (highest).
Andy
Old 14th July 2014, 04:24 PM   #6
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Power at 0.01% distortion makes a lot smaller wattage figure than power at 10% distortion, despite the fact that one amplifier could do both figures. 70's advertised low distortion thus the power figures were smaller. Today advertises maximum wattage while disregarding practicalities, in order to get much bigger wattage figures. The same amplifier can be advertised either way.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 14th July 2014, 04:56 PM   #7
woody is offline woody
Speakers of yesterday tended to be a lot more efficient and just a few watts was all you needed. They also tended to be much larger. Then with the advent of cheap power from solid state amps most speakers became smaller and a lot less efficient.
Old 14th July 2014, 04:59 PM   #8
In the 1980's I used 4 off 50watt Fane loudspeakers with my 225WRMS amplifier and it rocked most venues I played at. Got asked to turn it down on a few occasions.
I haven't found modern speakers to be anywhere near as efficient as those Fane 50 watters.
Old 14th July 2014, 05:05 PM   #9
Vostro is offline Vostro  South Africa
Vostro's Avatar
Originally Posted by SY View Post
42.
I agree fully
Old 14th July 2014, 05:58 PM   #10
palstanturhin is offline palstanturhin  Finland
palstanturhin's Avatar
10
What is the best power for an audio amplifier?Hide this!Advertise here!
Scalar Audio Power Amplifier ANADIGIT Solid State 4 17th May 2010 01:11 PM
C-audio SR606 Power Amplifier kamskoma Solid State 51 22nd July 2009 11:28 AM
designing an audio power amplifier mhcw550 Solid State 5 14th May 2006 03:36 PM
crest audio power amplifier hienrich Solid State 7 18th January 2005 12:28 AM
