Luxman L-410 Power AMP with Yamaha AX-1070 as Preamp connetion problem? - diyAudio
Old 8th July 2014, 10:17 AM   #1
oszkar is offline oszkar  Romania
Default Luxman L-410 Power AMP with Yamaha AX-1070 as Preamp connetion problem?
Hello!
I have a Luxman L-410 and a Yamaha AX-1070 connected as follows: Yamaha AX-1070 as Pre-amplifier and Luxman L-410 as Power Amplifier.
Problems and questions:
1. How come they work together only interconnected as it is on them two on the Pre-Out plugs both on Yamaha and Luxman, should it not be: Yamaha Pre Out, Luxman Main In?
2. Why do I have to turn the volume up on the Luxman to start putting some load in the speakers for the music to play. Should it not be no volume pot turning at all since it is a power amplifier?
3. Would Brumm accour on the relays of the Luxman if I would let the volume pot the same on turn off, turn on of it when it is time to play?
- To answer a question of yours if ever comes into discussion: I have connected them togheder: Yamaha on the Pre - Out, Luxman on the Main In and no result with every button pressed and tape functions misc. and recording.
Thank you!
Old 8th July 2014, 10:22 AM   #2
Here are some pics of what is happening on the connections back panels of the two components: 1. Luxman, 2.Yamaha.
Old 8th July 2014, 10:40 AM   #3
And where did you feed the input...
Gajanan Phadte
Old 8th July 2014, 01:12 PM   #4
All the inputs go in to the Yamaha. It goes like this: Source --- Yamaha --- Luxman as Power --- Speakers.
Old 8th July 2014, 11:02 PM   #5
llwhtt is offline llwhtt  United States
The volume control of the Luxman is grounding the signal at the pre-amp out RCA jacks, that's why you need to turn the volume up on the Luxman. What happens when you use the main in jacks of the Luxman and the signal processing switch set to "ON"? The "signal processing" switch isolates the power amp from the pre-amp.
Craig
Old 9th July 2014, 11:36 AM   #6
The signal processing is the tone control knob isn't it? I havve put a speaker on Left Side / Spk A on the yamaha and sound came out only on Direct, that means Direct knob pressed for direct to be switched on.
Old 9th July 2014, 03:07 PM   #7
No, it's the switch on the rear of the amplifier, switch it to "ON" and now the pre-amp is disconnected from the power amp.
Craig
Old 9th July 2014, 05:03 PM   #8
Thanks a million! It works very good!
Old 10th July 2014, 08:12 AM   #9
Why would you use the Yamaha as a pre-amp? It can only do one thing - degrade your signal.
The Luxman does not have a pre-amp at all. It's a straight power amp with an source selector and volume control. The tone controls are in the feedback loop and can be disengaged completely.
However, given the age of your Yamaha - I would bet it doesn't have a pre-amp either. So you're basically moving the source selector and volume knob to a different box, which is totally unnecessary.
I would remove the Yamaha entirely and enjoy a less cluttered stereo with a sleek looking Luxman in the middle.
EDIT: I was wrong. The Yamaha has a whole lot of crap going on in the pre-section. I would definitely recommend removing that completely.
Old 10th July 2014, 09:35 AM   #10
I feel the same, but I use the Yamaha because i have all on remote, source selector, volume, power on/off. The sound of the Luxman that comes out in the speakers is just a pleasure to listen to anyway.
Yamaha AX-1070 vs SONY TA-F770ES oszkar Solid State 5 22nd January 2014 07:53 PM
Luxman L-410 GEBRUIKER Swap Meet 0 19th November 2013 10:49 PM
diagram of YAMAHA amp AX-440 leonida Solid State 7 19th April 2013 01:27 PM
1988 Yamaha ax 700 intgrated amp twc5964 Solid State 1 6th March 2013 09:01 PM
yamaha ax 470 problem harrydg Solid State 3 17th May 2011 07:57 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
