Luxman L-400; which are the coupling caps? - diyAudio
Old 7th July 2014, 01:00 PM   #1
Default Luxman L-400; which are the coupling caps?
Guys,
I just purchased a Luxman L-400 integrated amp, I want to replace the output caps and the coupling caps right away. I found the output caps (10,000 electro's) but am having a hard time with identifying the coupling caps. Could one of you that is better at reading schematics look at the service manual on this site: Luxman L-400 Manual - Duo Beta Stereo Integrated Amplifier - HiFi Engine (the schematic that is on this link next to the service manual is for three different models and was useless to me)
Thanks, Wire Nut
Old 7th July 2014, 02:42 PM   #2
DF96 is offline DF96  England
If you don't know what they are, why do you want to replace them?
Old 8th July 2014, 01:20 PM   #3
Because I have replaced them on my other amps including an Alta Vista platinum upgraded Counterpoint... (Google it), and I like the sound of Mundorf caps.
If you are not being a help- you are being a bother.
Old 8th July 2014, 01:54 PM   #4
Send a message via Skype™ to JonSnell Electronic
Read the service manual. there are quite a few! You will be best advised to keep to the designers values and not change them.
www.flyingmole.co.uk For World Wide support for Flying Mole, Class D, Refurbishment and Repairs. www.jonsnell.co.uk
Old 8th July 2014, 02:44 PM   #5
SY's Avatar
Actually, his question should provoke some thought and possibly a bit of research beyond voodoo claims. It's more helpful than you are appreciating.
And while they may not be as strong as apes, don't lock eyes with 'em, don't do it. Puts 'em on edge. They might go into berzerker mode; come at you like a whirling dervish, all fists and elbows.
Old 8th July 2014, 07:43 PM   #6
rayma is offline rayma  United States
Guys,
Thanks, Wire Nut
The two 10,000uF caps are in the power supply, not for output coupling.
The two amplifier outputs are direct coupled, with the usual 100uF capacitors in the ground legs of the NFB loops. There are lots of coupling caps in this unit.
Old 8th July 2014, 08:41 PM   #7
There are no speaker output coupling caps, and there are no electrolytic caps in the signal path. You do not need to do anything here because it won't improve the amp in any way. Your Mundorf caps will - if anything - reduce the performance of Luxman's well thought out and excellent design.
Your attitude is frankly quite offensive.
Old 8th July 2014, 11:55 PM   #8
Unfortunately, there are a number of electrolytic coupling caps in this unit, such as at the inputs of the phono preamp and at the inputs of the power amp.
There are also electrolytics to ground in the NFB loop to control the DC offset.
Old 8th July 2014, 11:59 PM   #9
Yes, and they're all more than 30 years old. About due regardless, I'd say.
Old 9th July 2014, 12:10 PM   #10
Thanks to all... no wonder I could not find them-there are so many! I will be replacing the electrolyes, probably a section at a time.
Luxman L-116a Caps Jonas83 Solid State 1 25th November 2010 10:00 PM
Coupling caps Luxman pre-amp Narks Solid State 0 30th July 2010 11:23 AM
no coupling caps ray bronk Tubes / Valves 2 20th May 2008 08:10 AM
coupling caps el capitan83 Tubes / Valves 10 17th December 2004 05:25 PM
coupling caps??? AudioGeek Tubes / Valves 14 16th September 2004 01:05 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
