Luxman r-1050 troubleshooting - Page 2 - diyAudio
Old 8th July 2014, 10:12 AM   #11
I now have 2 meters connected. on the left channel the lowest setting is 68mA on the right the lowest setting is 89mA..
Old 8th July 2014, 11:04 AM   #12
Welcome is offline Welcome  France
Welcome's Avatar
If I recall there are two fuses on each channel. You're only measuring across a single fuse, right? Also, only remove one fuse per channel. Those numbers seem doubled. Otherwise, we have problem that I cannot quite understand. Too much current there, obviously. Does the amp run hot? It's only supposed to be slightly warm - if that.
Is the battery fine in your meter? A low battery can cause all sorts of unpredictable readings.
Old 8th July 2014, 12:16 PM   #13
yes I do measure with one fuse removed. while browsing the web for images I noticed this one looks different, it seems modded. maybe that's why the bias is higher.
Old 8th July 2014, 07:45 PM   #14
Welcome's Avatar
I've seen that board before. I think it's the NL company Audioscript that put that in there. They apparently liked to screw around with their products before selling them, adding in a bunch of junk for some reason. Here's some mention of that (not the same amp though) - Luxman audio products
That board is in the tuner, though, so it should have no effect on the idle current of the power amp.
Old 8th July 2014, 07:54 PM   #15
Ah searching audioscript revealed the modification to be an anti-birdie filter... I used two different current meters so the readings are correct... Could a broken potmeter be the problem?
Old 9th July 2014, 12:27 PM   #16
checked the potmeters.. they are fine!
do the speakers have to be disconnected when setting the bias? When testing without the speakers connected I measure 48mA
then a last question, In some old tube amps i've added a primary 12v winding in series with the primary of the power transformator. this is because the voltage from the outlets are about 10v higher these days. is this mod needed for this solid-state amp or won't the extra voltage hurt the amp?
Old 10th July 2014, 08:06 AM   #17
Welcome's Avatar
Yes, no speakers, no source - nothing connected. Volume at minimum. Forgot to mention that.
The extra voltage won't hurt anything. Running 220V units at 230V is no problem whatsoever.
Old 10th July 2014, 09:38 AM   #18
and thanks for you help!
Problematic receiver - Luxman R-1050 Hoya Fan Solid State 21 14th January 2017 10:00 PM
The Luxman R-1050 is in protection mode after a lightening storm marauderx Solid State 2 12th May 2012 04:24 AM
Luxman R-1050 trouble raveenvijendren Solid State 14 1st October 2007 09:17 PM
Luxman R-1050 Receiver (circa 1979) dtm1962 Swap Meet 0 17th September 2006 02:15 PM
Luxman R-1050 michelbouletb Solid State 0 9th February 2005 06:38 AM
Copyright 1999-2017 diyAudio
