Looking for a pot supplier (no, not that kind) - diyAudio
Old 4th July 2014, 04:58 PM   #1
THUMP LUMP's Avatar
Default Looking for a pot supplier (no, not that kind)
I have searched Mouser, Digikey and a few others with no luck. That's not to say they don't have it and I just couldn't find it.
I'm looking for a dual pot that has an inner and outer shaft to control each wiper separately. All I find have each wiper controlled by a single shaft, turning each in unison. Below is a pic of the type I am talking about.
THANKS
Old 4th July 2014, 07:49 PM   #2
Vintage pots are super hard to get ahold of. Even something as simple as a potentiometer with a knurled shaft longer than the usual 10 (or was it 15) mm is impossible. I think your only option will be from a donor unit. Is it an old Yamaha or Marantz amp that you are working on?
Old 4th July 2014, 07:55 PM   #3
THUMP LUMP's Avatar
Actually, it's something new and I could use a pot that is this style, old or new. Trying to keep front panel clutter down. To many pots as it is.
Old 4th July 2014, 08:14 PM   #4
Bare is offline Bare  Canada
And who is to blame for wanting "Too Many" pots ? :-)
Vintage ones are in my experiences damaged Junk.
Vintage were of early design and finite durability.
Age has taken their toll even on used as well as NOS ..new/unused ones.
Frankly I'd rethink my number of pots/controls wish list.
Old 4th July 2014, 08:14 PM   #5
KatieandDad's Avatar
Good ole E-Bay.
concentric shaft | eBay
Old 4th July 2014, 08:28 PM   #6
THUMP LUMP's Avatar
Bare.....The number of pots needed it rather fixed, which is why I was looking for this type.
Katieanddad......I took a look at eBay/US and found a few. I was hoping for better ones (conductive plastic).
Anyone else? I really don't care to go 2U rack spaces. Though, I maybe could add some VU meters that way.
Old 4th July 2014, 08:37 PM   #7
Nico Ras's Avatar
Originally Posted by KatieandDad View Post
Good ole E-Bay.
Well done!
Kindest regards
Nico
Old 5th July 2014, 02:09 AM   #8
Originally Posted by THUMP LUMP View Post
.....I was hoping for better ones (conductive plastic).....Anyone else? I really don't care to go 2U rack spaces. Though, I maybe could add some VU meters that way.
Perhaps you are at the limit of availability with the Alpha types shown. Vintage guitar/amp types will prove to be large and have high values, so using 1U rack size cases may not be that simple and economical on panel space. Note that each type/brand will also have different inner/outer shaft hole sizes and knob requirements. Good luck with some of the more likely combinations.
Stock plastic pots are generally single gang. For professional audio use, I would think multiple gang (expensive) custom builds are still made up to order.
Here's a wide range of types including conductive plastic and some interesting notes, glossary and FAQs. Note, concentric types are available - but as custom builds - obviously no prices. http://www.potentiometers.com/
regards
Old 5th July 2014, 04:57 AM   #9
THUMP LUMP's Avatar
Thanks for that Ian. The more I refine what I am doing, I do believe that a 2u rack enclosure will work out for the best. It's the least offending compromise and will allow room to add things (like the aforementioned VU meters).
Turn a log pot into a (kind of) linear pot osterchrisi Parts 4 12th October 2011 01:40 PM
dual gang slide pot supplier (uk) advice synergy Parts 8 1st November 2006 11:42 AM
Volume control : - pot' or pot' variable feedback resistor (gain) ? ash_dac Solid State 5 1st August 2006 05:07 AM
Effect of using 50k pot instead of 100k pot in tube preamp? KT Tubes / Valves 5 17th February 2006 09:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
