15 watt amp need to add a line out - diyAudio
Old 12th January 2004, 04:03 AM   #1
Default 15 watt amp need to add a line out
I have a Danelectro Nifty Seventy bass amp (15 watt) that I need to add a line out to run a mono cable into the mixer. I have a 1/4 mono phone jack and I know one side is ground, but I'm not sure where to wire the signal line to. Should it be pre-amp? Any help would be appreciated.
I've looked for a schematic, and I'm not finding one, but I assume there is a specific place where this line is usually wired. (???)
Thanks for any ideas -
ferenczy
Old 22nd August 2007, 09:00 PM   #2
engels is offline engels  Israel
engels's Avatar
Default dano
I'm sure I'm a little bit late with the reply.
Anyway, the Nifty Seventy bass amp has a headphone jack which could be used as a line out. Why not take a guitar cord and plug it there?
Old 23rd August 2007, 02:46 AM   #3
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
You can add 2 resistors voltage attenuator.
how to combine Line array and transmission line together Jared Multi-Way 7 15th December 2012 01:20 PM
Akai GX 265D line voltage on line outs? ShorBird Solid State 11 26th January 2009 11:44 PM
Peerless V-line XT line woofer discontinued first_1st Multi-Way 1 12th August 2008 04:55 PM
Line output as line input transformer? bambadoo Tubes / Valves 7 22nd January 2008 06:44 AM
Line array tweeter line - On left or right? dhenryp Multi-Way 4 9th March 2005 11:35 PM
Copyright 1999-2017 diyAudio
