Nad 214 muting circuit - diyAudio
Old 27th June 2014, 11:48 AM   #1
Default Nad 214 muting circuit
Hallo all,
I have got a problem with a Nad214 amp. My problem seems to be C222 or C223 in the muting circuit. The current electro caps are 0.47uf 100v and my problem is that I struggle to find them in 100v package. Can I connect two 1uf 63v caps in series to replace the 100v caps ? Is it really necessary for 100v caps, as the rail voltage looks like 52vdc ?
Jan
Old 21st July 2014, 07:10 PM   #2
Kay is offline Kay  Germany
if you like to use a caps like MKS or MKT with 63Vdc,
I see no problem
but
"two 1uf 63v caps in series to replace the 100v caps" it's o.k. too
best regards
Kay
Old 21st July 2014, 07:27 PM   #3
Mooly's Avatar
C222 can see the full supply (104v ?) if the lower transistor is on. So a 100 volt cap seems too low here. The other one, I'm not sure what voltage swing that might see as its determined by the internals of the IC to some extent.
Installing and using LTspice IV. From beginner to advanced.
Old 21st July 2014, 07:32 PM   #4
Mooly's Avatar
Is that line zero volts that the emitter goes to. If so then disregard what I said over the voltage rating and yes, 63 volt is OK
Old 27th July 2014, 12:46 AM   #5
"Is that line zero volts that the emitter goes to"
yes
best regards
Kay
Old 27th July 2014, 07:20 AM   #6
Mooly's Avatar
Thanks, so the 63 volt rating as you mentioned earlier is OK. It was me reading the circuit wrong at a quick glance.
Nad 214 Vrystaat Solid State 11 27th February 2015 05:52 PM
Wanted NAD 214 cmitch Swap Meet 0 8th March 2013 11:56 PM
NAD 3020A Muting circuit?? bmmach Solid State 2 25th September 2011 01:23 PM
Copyright 1999-2017 diyAudio
