Difference on Rega Elex and Mira 1 - diyAudio
Old 26th June 2014, 12:01 PM   #1
aolsen is offline aolsen  Denmark
Default Difference on Rega Elex and Mira 1
I have a Rega Mira 1 but it is "falling apart" (rca plugs falling off when dismounting cables and input and volume dials are noisy).
Now I have the oppurtunity to buy a Rega Elex 1 and it looks the same so my question is basically what's the difference between those 2 - like output power, sound quality, features etc..
Old 19th August 2014, 06:49 AM   #2
mashley_nad's Avatar
Basically the Mira has remote control and slightly more power. I have owned an Elex and currently own a Mira (both Mk II).
I only went to the Mira because I wanted remote control, but it does have that extra power. Plus you have pre-amp out and main-in sockets (there's an internal switch to bypass them).
Rega Elex (specs from manual):
Input Specification
Tape Input Sensitivity : 205mV (Load 18kOhm)
Aux Input Sensitivity : 205mV (Load 18kOhm)
Tuner Input Sensitivity : 205mV (Load 18kOhm)
CD Input Sensitivity : 390mV (Load 30kOhm)
Disc (Moving magnet) : 3mV (Load 47kOhm) Max input level 104mV
Output Specification
Power Output :
35W into 8 Ohm load @ 1kHz or
57W into 4 Ohm load @ 1kHz
Tape Output :
345mV (10kOhm load) with rated input sensitivity
Power Consumption :
125 Watts with max output
17 Watts Quiescent
Mira 2000
As far as I can tell from circuit this is almost identical to Mira II except for input switching which went from electro-mechanical rotary to reed relays.
Maximum power: 61Wpc in to 8 ohms, 91Wpc in to 4 ohms.
CD/Tuner/Line 1/Line 2/Tape sensitivity: 220mV for full power.
Line impedance: 10k ohms.
Phono (moving-magnet): 2.1mV. Load 47k ohms (in together with 100pF).
Power amplifier input for rated output = 818mV.
Impedance 24k ohms.
Preamp output turn (with rated input levels): 818mV @ 470 ohms.
Power amplifier gain: 28.8dB.
Power Consumption 225W.
I've attached the only review with test results for a Mira Clamshell that I've ever found ... sorry it's in Polish!
Hope that helps ...
NAD C730, NAD C541i, Denon DR-M14HX, NextWave DAB-390; NAD 7100, NAD 5000; Rega (clamshell): Mira II, Planet II, Radio R.
Old 19th August 2014, 06:51 AM   #3
BTW your Mira Mk I's issues are easy to fix for anyone with some basic electronic (especially soldering) skills ...
Old 20th August 2014, 08:09 AM   #4
Also BTW - The Luna is a Mira but without remote control.
Rega Mira 3 schematic Polesov Solid State 20 27th September 2012 09:30 AM
Idling current in Rega Mira 1, 2 or 3 2N6658 Solid State 5 17th March 2012 04:05 AM
Advice on repairing clamshell Rega Elex (Brio/Mira/Elicit) mashley_nad Solid State 8 27th November 2011 11:39 PM
Rega ELEX runs hot mashley_nad Solid State 0 10th January 2011 11:59 PM
Need Rega Elex Schematics Lewis Moon Solid State 6 6th September 2010 07:41 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
