German Translator Please
Old 26th June 2014, 03:27 AM   #1
allen6266 is offline allen6266
Default German Translator Please
Could someone please translate this for me, need to adjust bias for Denon Intergrated Amp PMA-980R.
Thank you very much!!
Old 26th June 2014, 05:16 AM   #2
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Instead of waiting, type the text yourself in any word processor (or simply Notepad), copy and paste into Google Translate.
Be careful to avoid mistakes, including all punctuation signs, accents (ümlaut, etc.) so as not to cheat translator.
In 15 minutes you´ll have your answer.
Post results for review, translators sometimes yield cryptic results.
Good luck.
Old 26th June 2014, 05:44 AM   #3
MarcelvdG is offline MarcelvdG  Netherlands
I'm neither a native speaker of German nor of English, but this is my translation:
QUIESCENT CURRENT
Set-up
1. Put equipment in normal position and shield it from air flow from airconditioning or fan. Do the adjustment at a temperature between 15 degrees C (59 degrees F) and 30 degrees C (86 degrees F).
2. Put the controls like this:
MAINS SWITCH -> off
VOLUME CONTROL -> Fully counterclockwise, minimum volume (VR801) and ?trimmable resistors? (VR501, 502, 503, 504)
LOUDSPEAKER CONTACTS -> Open, without loudspeaker or other load
Adjustment
1. Remove cover. Then connect a DC voltmeter to the measuring points of the power supply unit (1U-2369-1 or 1U-2422-1)
2. Connect mains and switch on. After 10 seconds, adjust the voltage to 5 mV +/- 0.5 mV by turning VR501 (left) and VR502 (right) clockwise
3. Let it heat up for two minutes, then readjust the voltage to 5 mV +/- 0.5 mV using VR501 and VR502.
4. Let it heat up for 10 more minutes, then readjust the voltage to 5 mV +/- 0.5 mV using VR501 and VR502.
5. Apply the 1 kHz, 10 mV RMS signal at the input of both channels and put the main volume control at maximum.
6. Make sure that the read-out of the DC volt meter becomes a slightly bigger value (10 mV or less), then turn VR503 (left), VR504 (right) clockwise to adjust the voltmeter to 30 mV +/- 3 mV DC.
7. After two minutes, readjust the voltage to 30 mV +/- 3 mV using VR503 and VR504.
8. Let it heat up for another 10 minutes and readjust the voltage to 30 mV +/- 3 mV using VR503, VR504.
Old 26th June 2014, 06:27 AM   #4
Danke!
German Translator PleaseHide this!Advertise here!
APIB-LPT translator needed flozki Equipment & Tools 1 5th November 2014 11:53 PM
German Class D ecodoppler Class D 4 13th April 2008 07:21 AM
new german user triodix Introductions 3 4th October 2007 09:52 PM
Translator Required lawbadman Class D 1 4th April 2005 11:01 PM
German Friends ; tell me more .. ZERS Digital Source 6 9th August 2004 01:40 PM
