IC Bias using LT1116
Old 18th June 2014, 02:39 PM   #1
rhythmsandy is offline rhythmsandy
Default IC Bias using LT1116
what are the pros and cons of using a IC based biased controller like stated in the bob cordell book? will it reduce the distortion to a considerable level?
Is there anyway that we can switch on an off the transistors prior the input signal so that the distortion can be reduced and the amp gets into class A mode in terms of distortion with little heat dissipation.
something like this with an offset like an envelope
http://electronicdesign.com/site-fil...9/74299_f4.gif
IC Bias using LT1116Hide this!Advertise here!
Dynamic Bias - Active Bias - Automatic/Self biased - Overview wanted tiefbassuebertr Pass Labs 18 26th December 2017 03:24 AM
LT1166 bias IC Sebastiaan Solid State 2 3rd September 2011 04:21 PM
search pcb with IC tl494 or other Ic to build a smps caraudio Ground Zero Car Audio 0 13th December 2010 05:58 PM
Replacing Bias IC with Individual Transistors scsidude2 Solid State 5 23rd May 2010 07:28 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 02:30 AM
