Christmas tree bulbs for my Carver dial lights - diyAudio
Old 15th June 2014, 01:22 AM   #1
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default Christmas tree bulbs for my Carver dial lights
Well my CFM-15cb Carver finally blew the panel lamps. I know they're in series. I figured one is blown, so I'll take the good one & measure it...& see if it matches a Christmas tree bulb. If it's less & doesn't draw so much, all the better as a sub-voltage will keep it alive longer. So dusty inside!!
__________________________________________________ ____Rick.........
Old 16th June 2014, 03:12 PM   #2
indianajo's Avatar
Christmas tree bulbs are LED's now. They drop typically 1.3 v. You need to set the resistor to draw about 10 ma. Many such replacement bulbs have an internal resistor already, so you have to take a power supply and an ammeter to find out what is in there.
The white ones may drop more voltage as they can be several junctions in series.
Some circuits can pick up noise from the sharp edge of the semiconductor junction. Depends on how close the LED is to the high gain circuit points.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Under the Christmas Tree - Valve Amplifiers 4th Ed. Magz Tubes / Valves 6 26th December 2012 04:12 PM
Christmas tree positively effect room acoustics? sharpi31 Everything Else 3 9th December 2012 02:18 PM
Testing Christmas Light Bulbs Speedskater Everything Else 6 24th December 2011 12:13 AM
Transformer wiring for christmas tree repair kanifee Everything Else 1 3rd December 2008 02:04 PM
Carver M1.5t Flashing Yellow Lights jjmartec Solid State 7 12th July 2005 07:15 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
