Hitachi HA-250 Amp no output
Old 11th June 2014, 03:54 PM   #11
sgrossklass is offline sgrossklass  Germany
If you even found 50 mV (> 200 mA when measured over one 0.22R resistor -- I = V/R) originally, chances are that the bias pot has contact issues and should be cleaned / replaced (in which case I'd contemplate going multiturn). Not uncommon in Hitachi amps. Excessive quiescent current makes the output transistors much more susceptible to secondary breakdown due to heating.
Most Japanese amps run 30-50 mA of idle current, mainly for thermal considerations.
Old 11th June 2014, 06:00 PM   #12
sesebe is offline sesebe  Romania
Please check what I wrote here:
Originally Posted by sesebe View Post
I do not have/know exatly the schematic for HA-250 but from photo looks exatly like HA-330 which I have opened on my working table for revival.
For HA-330 the idle current need to be adjusted to have 8mV±4mV on emitor resistance which it is by the way 0.22Ω.(according to service manual)
This means that you set the current to 100mA and not to 22mA for 22mV.
On my amplifier I put supplementary in parallel with the original circuit, a multiplied diode thermaly connected with the heatsink of the power transistors for a better idle current stabilization (original circuit it is thermaly connected to predriver and not with power transistors).
At HA-330 the SCR it is for output short circuit and SOA protection and not for DC out protection. Check the values of resistors around this SCR.
Old 11th June 2014, 06:59 PM   #13
In my case the red circle resistors are devalued and need to be changed.
For your case with high DC offset, change the blue marked capacitor.
I already change most of small filtering capacitors and I must change the yellow marked capacitors.
The yellow marked I want to change because now it is sound very nice but can not be compared with my tuned Yamaha A-6A. The sound it is somehow noised even if I do not have any noise without signal.
You can see my modification too.
Old 12th June 2014, 02:29 AM   #14
johno210 is offline johno210  Australia
Default Thanks for the feedback
Pictures explains a thousand words.
Am I correct in thinking the physical removal of SCR901 allows the base of Q901 to go low which allows the coil of RL1 to conduct thus operating the relay ? Yes will investigate the replacement of VR701 with your workaround.
Cheers Johno
Old 12th June 2014, 07:24 AM   #15
Mooly's Avatar
When SCR901 is triggered it removes the +14 volt rail by placing what is effectively a "short" across zener diode CR802. That 14 volt rail is what turns on relay driver Q904 via base current supplied by R903. Q901, Q902 and Q903 provide DC offset protection and can disable the relay by pulling the base of Q904 low.
So there are two mechanisms. Over current detection via the SCR, which once triggered removes the 14v rail until the amp is powered off, and DC offset protection as described above.
Old 24th July 2014, 01:58 PM   #16
johno210 how is your amp?
I manage to finish to change all the marked components on my photos.
All "noise" and distorsion disappeared after I replaced the marked electrolitic capacitors with film capacitors 1u/63V WIMA (even in place of 3.3u and 0.47u).
Only C705 was replaced with an electrolitic.
After I replaced all devalued resistors was needed to correct resistor VR701 value from 68 to 120ohm in my workaround and I set the voltage drop across R720 to 4-5mV.
Now the sound of the amplifier it is simply awesome.
Hitachi HA-250 Amp no outputHide this!Advertise here!
hitachi ha-330 modification adason Solid State 45 15th January 2017 09:49 AM
Hitachi Ha-4700 JensRasmussen Solid State 27 17th August 2014 07:08 PM
Hitachi stereo amplifier HA-250 mark31385 Solid State 19 18th February 2014 11:33 AM
Hitachi Servo/RF-Amp HA12158NT ("HA 12158 NT", HA12158, "HA 12158NT") from Linn Karik tiefbassuebertr Digital Source 6 27th June 2011 01:14 PM
Hitachi HA-330 stereo amp circuit diagram mingson Solid State 2 16th August 2006 06:56 PM
Copyright ©1999-2017 diyAudio
