Technics sux320 amp low tinny bass - diyAudio
Old 3rd June 2014, 09:34 AM   #1
gavi101 is offline gavi101  New Zealand
Default Technics sux320 amp low tinny bass
Hi all
Hoping you can help or advise.
I have a technics sux320 set (amp,speakers,tuner,cd,tape deck,equaliser).
Having a strange issue with the amp and speakers. When the amp's balance knob is centred the bass from the speakers lack depth and sounds tinny when loud .... BUT when I move the Balace knob full left the bass comes hard and speaker sounds louder and when I move it back to center it's lacks bass and tinny AND when move balance full right again the bass is hard and speaker is loud but move it back to center it looses bass ;(
I have checked the speaker connections in the back and it's all correct.
Hope someone can help or shed some light.
Thnx
Old 3rd June 2014, 04:03 PM   #2
shredhead's Avatar
Reverse the polarity on one of the speaker outs. Leave the other channel alone and see if it gets worse or better.
Old 3rd June 2014, 04:44 PM   #3
See if the speakers need new foam surrounds or if the woofers are seized up. Did your speaker get dropped of knocked over (it can shift the magnet on the woofer). Also check the amp controls...
The stuff you don't know always humbles us.........
Old 4th June 2014, 08:09 AM   #4
Why Guys
Thanks for the replies
ill try reversing the polarity and see what happens.
No damage ...speaker cones/foam etc all fine and didn't dropped them as far as I know off.
Old 4th June 2014, 02:37 PM   #5
shredhead's Avatar
Might be a power supply problem too. Like it has enough power for one channel only but it drops out when two channels are on it. Looks like it is a fairly old receiver. Might be time to download the service manual and open her up. Check voltages from power supply.
Old 4th June 2014, 07:05 PM   #6
Most obvious is speakers out of phase, as already suggested.
Old 9th June 2014, 03:32 AM   #7
Hi Guys looks like you guys were correct it was out of phase.
Seems someone in my house hold may have kicked the wire of the push terminals on the speaker end (Left) and connected them incorrectly.
Unfortunately during my troubleshooting I was focused on the amp being the issue than the speakers (my bad) and didn't check the speaker push terminals.
Thanks all
TL072 based Electret mic pre-amp not working correctly... Tinny and quiet. fraseyboy Chip Amps 29 12th May 2014 04:31 AM
T-Amp - Metallic/tinny sound ? seawalker Class D 11 5th March 2012 05:19 PM
Low & chest bass make72 Subwoofers 25 27th January 2005 07:38 PM
my 1st diy tinny TDA1554 amp! help me.. deepanger Solid State 6 22nd November 2002 01:24 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
