phono design - Page 5 - diyAudio
Old 9th February 2004, 08:55 AM   #41
Aiace is offline Aiace  Italy
Ok Dimitri I think you right, here is the NF diagram.
but if you look at Hfe diagram you can see that gain at 100uA is half than 1mA. I think S/N at the end is almost the same.
If it's a mistake please tell me.
Thank you
Aiace
Old 9th February 2004, 01:53 PM   #42
Dimitri said than pickup can be modelled by 10-15 kohm. Now I've a question:
A MM pick up like GRADO (http://www.gradolabs.com/product_pages/cartridges.pdf)
has a resistance of 475ohm and an inductance of 45mH. That means 520 ohm @ 1kHz a lot far away from 10-15kohm od Dimitri.
What do you use to model pickup for noise and why?
Thank at all
Aiace
Old 9th February 2004, 03:52 PM   #43
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
Yes, this is a mistake. The differential dc _voltage_ gain of the first long-tailed pair will be (R2+R3)/(2*26mV/Ie+R1). It is nothing to do with hfe - current gain.
Yes, this is for typical MM pickup with a resistance of ~500ohm and an inductance of ~500mH.
I've opened the pdf of Grado, your pickup has ten times lower inductance. If it isn't a mistake I don't understand why Grado has that output . If the inductance of your MM pickup is ~50mH, leave everything untouched. You are lucky!
Old 9th February 2004, 10:40 PM   #44
Yes Dimitri Vu=gmd*Vd where gmd=Ie/(4*26mV)...so as high Ie as high the gain of Vd
Dimitri, I 've looked around for pick up inductance, and I think you give me a clue: I'm going to measure inductance of my pick up but at the moment I can't hear any noise from my phono
Hi
Aiace
Old 10th February 2004, 06:00 AM   #45
dimitri's Avatar
My dear Aiace
Donít put out your tongue at me . Think before you type .
This is not Vu-voltage, this is Iu-current! Ė and to remain E/2 voltage on collectors while changing Ie you should adjust R2,R3 correspondently
Very good
Ciao
Old 12th February 2004, 08:35 PM   #46
Ingenuously I trimmered RV1 before connecting the circuit to the pickup. After several days a suspicion is risen me....
I went to measure the outoput offset and it was 3V !!!!
So I trimmered again RV1 (with the pickup connected) and started to listen at same disks .... Fantastic !! It has been like I cleaned my glasses, or like I cleaned the kitchen windows from the vapor. Finally I obtained the transparency that I love.
Yes, my phono sounds very well, fast and deep low frequencies, very natural in human voices , extremely high dimanic sound, analytic like one x-ray, not noise at all.
I'm very happy of my work 'couse my thoeory of "virtual bilanced" was right
Thank you at all for your advices and patience
Aiace
Old 5th May 2004, 07:59 AM   #47
thanh is offline thanh  Viet Nam
thanh's Avatar
Send a message via Yahoo to thanh
why don't you use all fet?
RIAA Phono Amp Design Sheldon Tubes / Valves 51 24th December 2007 06:45 PM
Phono Preamp Design Needed AudioFox Tubes / Valves 9 15th June 2006 08:11 PM
Phono Pre-Design Input philipbarrett Tubes / Valves 22 5th November 2005 04:20 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
Copyright ©1999-2017 diyAudio
