2sk1058 or Exicon lateral mosfets?
Old 20th May 2014, 08:09 AM   #1
rhythmsandy is offline rhythmsandy
Default 2sk1058 or Exicon lateral mosfets?
I have a choice to choose either 2sk1058 or Exicon lateral mosfets.
Which one will be best to use for higher bias class A application preferably at 22V 1Amp bias per fet or at 32V .6 bias per fet.
Im just considering the best sound quality so which one to choose?
the cob of the 2sk1058 is lower than the exicons so what about the other parameters to be considered?
Old 20th May 2014, 01:38 PM   #2
just checked with the Renesas Distributor today and they said the 2sk1058 is going to EOL and hence recommending the
2SK2220 | Renesas Electronics Singapore
Is the above mosfet better?
Old 20th May 2014, 01:55 PM   #3
R.I.P.
Have you compared all the different datasheets for these Lateral mosFETs?
They are almost identical. Even the original Hitachi To3 2sk135/j50 are the same.
regards Andrew T.
Old 20th May 2014, 04:06 PM   #4
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by rhythmsandy View Post
Interesting - the 2SK2220 data sheet was issues nearly 10 years ago it'self so this doesn't bode well.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 20th May 2014, 04:28 PM   #5
What about the capacitances?
Old 20th May 2014, 04:37 PM   #6
Zero D is offline Zero D  United Kingdom
In more ways than 1
Old 20th May 2014, 04:50 PM   #7
Bigun's Avatar
Originally Posted by Zero D View Post
In more ways than 1
those kind of jokes should be illegal!
Old 20th May 2014, 06:17 PM   #8
R.I.P.
In more ways than 1
I'm a bit more than slow.
It took two readings for the subtlety to sink in.
regards Andrew T.
Old 20th May 2014, 07:47 PM   #9
@ AndrewT
Well @ least you got it now
Old 20th May 2014, 07:56 PM   #10
AMV8 is offline AMV8  United Kingdom
I have used Hitachi, Exicon and other mosfets in a number of amps. If it helps you I find that the Exicon mosfets are the best sounding ones around today.
However if you can find some in an old amp, I find the Hitachi mosfets still produce the clearest sound across the whole spectrum form bass to treble. The Exicon mosfets are very close.
I am not sure why this is as the specs all seem very similar. I suspect that the Hitachi specs were more conservative then other companies specs.
The only difference I have found between the mosfets from different companies when testing mosfets is in the Threshold voltages. The Hitachi mosfets had very close matching on Gate Threshold voltage, to within 0.03v, on mosfets with the same batch number. Exicon and other makes show a wider gate threshold voltage variation of 0.35v between mosfets from the same batch.
Also, if it helps you, I find that the output mosfets seem to benefit from a driver stage with a higher current capability than you would expect and from using VAS and driver transistors with low capacitance.
Don
2sk1058 or Exicon lateral mosfets?Hide this!Advertise here!
Exicon Lateral Mosfet doubts rhythmsandy Solid State 5 12th November 2013 01:52 PM
Drivers for the Exicon Lateral Mosfets? ECW20N20-Z n ECW20P20-Z rhythmsandy Solid State 8 16th October 2013 06:09 PM
X-Amp (LME49830 + Exicon Lateral Mosfets) danfo098 Chip Amps 28 14th October 2013 04:05 AM
Exicon lateral MOSFETs davygrvy Solid State 18 6th December 2011 10:56 AM
2A ClassA using EXICON Lateral lineup Solid State 4 31st January 2009 11:32 PM
