Some people loves a challenge .... - diyAudio
Old 18th May 2014, 11:52 AM   #1
destroyer X's Avatar
Default Some people loves a challenge ....
So, Uncle Charlie, in a genuine provocation challenge you...... because you are a challenge lover....to make a better Class A amplifier.
- First of all..... i would say...you gonna fail
- Second i would say....gonna waste your time
- Third thing i would say.... no one can do it
Several have tried...even the best from the best...the cream from the cream...this one has efficiency (30 watts RMS output)...and low distortion.... i can reduce distortion (THD) to less than 0.028%.
Great designers made good stuff..no one made so good as this one.
Let's see if you can beat this one....hehehehehe.... will fail.
You love open designs to tweak....here is your moment.
Conditions guys...1.9A each rail.... 36 volts each rail, THD less than 0.03%)
Picture shows an old friend of mine.... Akio..... one day i will tell you the one designed this one together uncle Charlie..... Morita is already dead.
This will be funny....sorry...Uncle Charlie already started to laugh...ahahahahahahahahaha!
regards,
Carlos
Power supply; ripple, filter, noise, stability and the use of capacitance multiplier... Portuguese and English; https://www.youtube.com/watch?v=sSm0ku1eIgg
Old 18th May 2014, 12:10 PM   #2
Default Please, post your Class A design
Post your simulation, your prototype if you have courage to build it and post movies and pictures about inspection using scope or spectrum analyzer
Enjoy...do you believe you can do it?
I doubt ( hehehe...arrogance is good to challenge) and challenging you to prove you can.
Voltage, current and power can be plus or minus 20 percent...no problem.
Picture was an advertisement made by São Paulo Government, to say people should cross street in the correct place...because there's a high speed lane to buses down here.... this advertisement was latter removed as looked too much shocking, but i have used and published in many amplifier threads, showing that i trust competition will be crashed easy by my amplifiers.... arrogance drive some people mad, others understand as challenge and build the stuff to see if they are really good in an attempt to crash Uncle Charlie...usually they do not do that..because my amplifiers are really nice.
Please, be aware that exist fake capacitors, to my amplifiers i suggest you to buy good, reliable brands to avoid to fake something this guy from Indonesia have faced.
regards,
Carlos
File Type: jpg 1012569_707791682613410_3230675107778967946_n.jpg (50.9 KB, 363 views)
Old 18th May 2014, 01:27 PM   #3
burbeck is offline burbeck  United Kingdom
hi Carlos
its great to see you back here with a little devil inside you
this is a very interesting challenge, i may try myself give me somthing to do and learn a bit about simulation if nothing else
regards
bob
Old 18th May 2014, 01:47 PM   #4
Bigun is offline Bigun  Canada
Bigun's Avatar
I don't think I saw a photo of you when you were so young man !!!
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 18th May 2014, 02:45 PM   #5
Default Ahahahahahah!...i love to have some fun
And there are people that gonna try....and this is interesting to see their ideas.
Where are the ones use to be buzzing around?...where are they?....hehehehehe
I am just kidding...of course people can do it...but will not be easy...this unit is awesome.
Picture ifrom the eighties... it has 34 years old....heheheheh...i was young....one day!
See this one...even older.
regards,
Carlos
Old 18th May 2014, 02:48 PM   #6
Default One thing is clear and guaranteed.....
People that decide to do will have fun, if assemble will have a very special amplifier...this is all guaranteed.
Designers of that stuff are very good ones...the one helped me is 100 times better than i am.
Now a days i am a boring old man.
regards,
Carlos
Old 18th May 2014, 03:02 PM   #7
Default If you decide to build..then have attention
The trimpot adjust the off set.
The iddle current you can adjust into the source resistors... reducing the value the current increase and the distortion reduces....increasing them you reduce current and reduce distortion...the circuit is already optimized...0.47 ohms up and 0.33 ohms down.
These guys that "thinks" they have knowledge will believe this is an error...hehehehehhe....no error.....it has a purpose.
This monster goes hot...aprox. 100 watts....but efficiency is awesome to a Class A..goes more than 28 percent easy.
I am not that special as a designer, but the guy did it with me is a monster ...the guys knows a lot...and one day i gonna tell you the name and you will be very surprised...one day...do not know the day...one day....first let's wait designers come to try to beat us...hehehehehe..this gonna be funny.
Where is Wahab?... he looks that knows a lot...also BV...... where is AndrewT, this one may know a lot.... where is Line up... where is Halojoy and Eva?... where is PMA?...i do think they have courage to face the challenge.... what do you think..will they come?
regards,
Carlos
Old 18th May 2014, 06:31 PM   #8
Default You see....no one!
If you ask help...then they do not come...if you challenge them to make something better..then they do not accept the risk or responsibility.... you see.
They can change to make it better..the way the usually do..when you do not invite them to suggest then they are there to bother...when you invite... no one.
You see.....something they love.. to put their fingers to make the unit better, to show flaws, or errors..then they come very fast...when it is to work and to show themselves to be under control, when people will do with them what they use to do with us..to be evaluating us...then they do not come.
Is this courage or something different?
regards,
Carlos
Old 18th May 2014, 06:34 PM   #9
Default We have an amplifier, a Solid State one, a class A one
in development, not ready, accepting modifications to increase performance (if the guy prove it gonna be better with simulations and real world stuff)...exactly what people say it is fair...to develop stuff in an union of minds.
Of course i will not assemble their ideas, will not work for them to try their ideas...want to be famous..then work.
Where are they?
regards,
Carlos
Old 18th May 2014, 09:08 PM   #10
Default We left something missed for you to fix
Symptom is overshot...but for sure you know how to fix this....it is basic in electronics.
regards,
Carlos
Portuguese who loves audio sendoushi Introductions 6 7th October 2013 01:44 AM
Google loves us godfrey The Lounge 30 25th March 2012 11:49 AM
Who loves Chocolate? alvincurt The Lounge 9 9th February 2010 06:11 AM
Who Here Loves Big Brakes? Logikal The Lounge 2 20th March 2009 04:00 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
