Pros and Cons of MOSFET VAS - diyAudio
Old 17th May 2014, 01:55 PM   #1
Belaji is offline Belaji  United States
Default Pros and Cons of MOSFET VAS
I always thought that the ubiquitous three transistor VAS was somewhat artificial. First we add a darlington to get the VAS input Z up, then we get too much current so we add another current limiting circuit. Why not something more direct.
Here is an approach I like, the MOSFET VAS. No base current (high Zin but some more Cin) and the maximum VAS current is set by R9. The MOSFET acts as a variable resistor in the Q6 current source. I'd like to get a variety of opinions on this.
Thanks,
Bela
Old 17th May 2014, 02:26 PM   #2
gannaji is offline gannaji  India
Kindly post the .asc file.
www.samritatrust.org
Old 17th May 2014, 04:59 PM   #3
udok is offline udok  Austria
To get realistic THD results, include the output stage. The output stage causes nonlinear loading.
The Mosfet with cascoce transistor Q6 does limit the max voltage swing which is bad.
The high input impedance of the Mosfet is of no use as the feedback capacitor C3 decreases the impedance to very low levels.
Mosfet normally have high capacitance and are noisier than bipolars.
Greetings,
Udo
Old 17th May 2014, 09:14 PM   #4
Testing the input and VAS stages separately can give valuable insights. Pick your favorite output stage.
Old 17th May 2014, 11:03 PM   #5
tvrgeek is offline tvrgeek  United States
I suspect there is a pretty good reason most amps have started to look very much the same. Sort of "Blameless" with a few variations. Why is this ubiquitous? Well, because it works pretty darn well. The 99% fix if you will.
Old 18th May 2014, 12:47 AM   #6
Sure it works well. But it seems inelegant to me. To me, there is art in electronics design... beauty in simplicity. The typical three transistor VAS seems more like brute force. Beta enhance, now too much current, oh lets put in a fix. I'm not saying this MOSFET approach is better, perhaps more beautiful in purpose.
Old 18th May 2014, 01:04 AM   #7
If you are in business, performance and cost counts. "Elegant" is for DIY. Go for it.
Old 18th May 2014, 01:23 AM   #8
I do both.
Old 18th May 2014, 02:07 AM   #9
I have some good result with JFET (2SJ74BL) at VAS. But about MOSFET, what kind to fit?
Old 18th May 2014, 09:41 AM   #10
Looks like M1 is running @ ~ 1.1Vds
Is that enough to get excellent performance?
Have a look at doubling R5 & R6 values.
Try tripling R7 & R8 values.
Do either of these changes compare well or badly to existing values?
Q6 is running hot, what about a To126 device?
regards Andrew T.
what are the pros and cons of valve amps? pkgum Tubes / Valves 24 26th January 2014 05:34 AM
What are the pros and the cons of those 3 vas ? tessier Solid State 72 6th December 2010 12:34 PM
Cons / Pros Borat Tubes / Valves 34 1st September 2009 12:52 PM
Rear tweeter - Pros and Cons Sony Multi-Way 2 26th August 2005 03:34 PM
Pros and Cons of this technique? G Tubes / Valves 35 23rd October 2003 05:37 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
