12V fan replace 24V? - diyAudio
Old 11th May 2014, 10:24 PM   #1
ro9397 is offline ro9397  United States
Default 12V fan replace 24V?
OEM fan is 80mm 24V single-speed w/on-off sensor. Toward less noise I consider replacing with THIS 92mm 12V 3-speed.
I presume the 12V runs OK but at slower RPM, plus its 15% larger size and highest speed setting provide adequate airflow. (Receiver has thermal protection circuit.)
Please advise.
Also, prior to above fan swap: I fist desire to install THIS zener diode to slow OEM fan speed for less noise. Mouser has MOQ of 1000. Who sells that part or similar functioning part in small numbers?
James
"Television is the poor man's whiskey." Russel Baker
Old 11th May 2014, 11:02 PM   #2
Sorry I got it backward. I see now the 12V fan runs at twice its speed at 24V with corresponding quick burn out (not slower speed as in the OP).
Someone posted a "12V zener" is appropriate to drop 24V to 12V. I'd much appreciate a link to the correct part.
James
Old 11th May 2014, 11:21 PM   #3
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
I had a need for a 24volt fan and had 2 12volt units on hand....stacked them up and ran them in series....seems OK.
http://www.evancotler.com
Old 12th May 2014, 02:09 AM   #4
ishiru is offline ishiru  Indonesia
ishiru's Avatar
zener would be good w/ a dropping resistor.
or the other technique, use regulator.
please mind the power dissipation of the fan.you might want a big resistor wattage like i did (now using regulator as 10W resistor getting pretty hot)
HDD - Tube DAC - XV-2 xover - Krell Clone 50 + 4W class A mosfet amp - Technics SB-2470 (modded)
Old 12th May 2014, 04:09 AM   #5
Another option...make a ccs circuit using a transistor. Saves the fan from high currents also.
Gajanan Phadte
Old 12th May 2014, 04:38 AM   #6
I'd much appreciate a schematic of your regulator circuit.
James
Old 12th May 2014, 04:39 AM   #7
Gajanan Phadte
Would you be so kind as to provide a schematic diagram?
James
Old 12th May 2014, 05:53 AM   #8
Google is your friend - there is a ton of info sitting on the web and ready to go.
This is as simple as it gets: 24V 12V DC DC Converter - Storage
Note that it may be assumed that experimenters know these regulators require a TO220 size heatsink.
regards
Old 12th May 2014, 06:53 AM   #9
Put the regulator behind the fan.
Old 12th May 2014, 08:16 AM   #10
Vostro is offline Vostro  South Africa
Vostro's Avatar
, linear regulator can get very hot. I use series resistor with fan, and then place 12v zener over fan, to steady voltage, so it doesn't creep up.
I don't care how hot resistor gets, no runaway effect here.
Knowing 12V fan, current draw makes calculating (guessing) resistor easy
Looking for 12v 24v psu Djryderz Power Supplies 1 4th November 2013 12:50 AM
24V DC computer fan speed control Vrystaat Power Supplies 11 24th March 2012 12:01 PM
Using a 24v SMPS for a 12v board? clawmd Power Supplies 2 11th September 2011 08:54 PM
Quiet 12V cooling fan for pro amp (24V supply)? Evenharmonics Solid State 7 10th January 2011 02:02 PM
24v to 12v converter moi Parts 5 15th September 2003 12:47 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
