Old 21st April 2014, 04:12 PM   #1
overmind's Avatar
Default Headphone amp - POP sound will powering ON and OFF
I am using a Headphone amp with DAC, Topping D2.
There will be a pop sound at the headphone output when powering on or off the unit. The pop sound is more prominent during powering off.
The original amp is using a PS of +15V. I had modified it to +/-15V for the analog circuit and +8V for the digital. The result is good, except I cannot get rid of the POP sound during power ON and OFF.
Diagram A is the output stage schematic. It is similar to that of the miniUSB DAC.
Diagram B: I isolated the output transistors bridge. NO POP.
Diagram C: I isolated the the OPAMP, OP275, the POP remained.
I believed the POP sound is due to the characteristic of the OP275.
I would like know how can I remove the POP sound from OP275.
If I have to change the OPAMP. What other opamp, without the power ON/OFF POP, can I use?
Is there anything I can do to improve the HF of this circuit.
I prefer HF to have more extension and more prominent and sound that is not airy.
I had tried adding a relay for muting the output, and I do not like the results, too much HF roll off.
OP275 Datasheet:
http://www.analog.com/static/importe...eets/OP275.pdf
A: Original Circuit:
B: Transistor Bridge:
C: OPAMP:
Old 21st April 2014, 09:40 PM   #2
jaycee is offline jaycee  United Kingdom
Does it happen if you ground the input of the opamp? if no, then the pop is coming from your source.
Circuit B will not function at all. Circuit C means the opamp is directly driving the output, and the transistor stage is completely unused.
Old 21st April 2014, 10:05 PM   #3
jcx is offline jcx  United States
not endorsing a particular product but The ε12 Muting / Protect Circuit shows a output relay board just for headphone amps
Old 21st April 2014, 11:37 PM   #4
overmind's Avatar
Circuit B & C are for debugging.. Just to identify where the pop sound is coming from. The circuit has to be reverted to A to be functional.
Old 21st April 2014, 11:42 PM   #5
overmind's Avatar
Yes. Adding a muting relay will mute the pop sound. I had tried, I found I did not like the sound of the relay in series of the output.
I am considering to use other relays.
Old Yesterday, 06:13 AM   #6
Don't put the relay in sreies with the output, use it as a shunt to ground, that way it's not in the signal path when the contacts are open.
Mike
Old Yesterday, 09:12 AM   #7
overmind's Avatar
Mike
Yes.. This is good idea..
Old Yesterday, 09:30 AM   #8
overmind's Avatar
I do not have the space for timing circuit..
The POP sound is more serious during powering off.
I will use two DPDT relays to short out the two points for muting, so I will not have any short-circuit current issue. I hope.
I will also try other opamps.
Old Yesterday, 11:49 AM   #9
I recommend you don't do it that way, it will cause 100% positive feedback (oscillation.) I meant you should shunt the output to ground. Shorting the output shouldn't cause any trouble for the small amount of time it takes for the supply rail to discharge.
Mike
A curious Inquiry involving internal headphone amp/powering multiple earbuds? rebz Headphone Systems 3 16th April 2013 06:17 AM
Powering a headphone amplifier with DC filament supply cr0wl3y Tubes / Valves 3 16th October 2010 04:27 PM
info about powering a headphone amplifier spendorspain Headphone Systems 3 2nd August 2008 04:33 PM
Powering LM 3886 from Headphone Output, MAC. problem dxtr Headphone Systems 14 8th April 2008 01:36 PM
buzzing and pop sound when fender power amp is turned on zaboomafoo Everything Else 0 27th August 2004 05:12 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
