The many versions of the NE5532 and it is confusing! - diyAudio
Old 21st April 2014, 05:32 AM   #1
fap is offline fap  Australia
Default The many versions of the NE5532 and it is confusing!
G'day all, last night I was about to place an online order for some NE5532 op amps from my usual online supplier but I find that they list several versions of the NE5532 (NE5532AP, NE5532P and probably others!)
The specs all look the same but there is an appreciable difference in price between these two items! Can anybody tell me what the differences are? I presume it is a 'noise' difference, or is it? I am after the 'quietist' version. It is very confusing! Regards, Felix.
Old 21st April 2014, 06:47 AM   #2
A is the lowest guaranteed noise option. The rest is unimportant, other than TI's 5532s are said not to measure as low on THD as others.
Unfortunately low noise, low THD comes at a premium with any electronic part options or there would be no demand for standard parts.
See here: what is different between NE5532AP and NE5532P - Precision Amplifiers Forum - Precision Amplifiers - TI E2E Community
Ian
Old 21st April 2014, 06:57 AM   #3
Mooly's Avatar
You could also do worse than go with the 5532's successor, the LM4562 which offers a step up in performance all round (and its considerably quieter if your application is designed to exploit those limits).
Old 21st April 2014, 07:24 AM   #4
G'day all, I've decided to go with the LM4562 but the only version I can presently buy is the 'powerwise' version. Does anyone know what 'powerwise' means? Regards, Felix.
Old 21st April 2014, 10:10 AM   #5
Mooly's Avatar
I've never come across the term before but see that all Farnell descriptions of the part now have this term. The TI data sheet (latest 2013 issue and revised) makes no mention of it.
I would be 100% certain that nothing has changed with the device, if it had it would be a different part/device number.
Old 21st April 2014, 10:12 AM   #6
G'day mate, many thanks. Regards, Felix.
Old 21st April 2014, 11:05 AM   #7
"Powerwise" - selected low power consumption TI components promoted through distributorships in training courses. Here's Digi-Key's introductory course outline.
http://dkc1.digikey.com/au/en/tod/Te...PowerWise.html
I think its just part of marketing hype aimed at non-professionals or those otherwise dabbling in microprocessor control and audio systems. Certainly, there's no mention of any special enhancement or change in the products.
Ian
Old 21st April 2014, 11:43 AM   #8
Mooly's Avatar
Marketing hype indeed. As good as the 5532 and 4562 are, they are some of the most power hungry opamps in common use.
Confusing fuses Black Stuart Parts 3 26th March 2013 01:28 PM
Confusing about grounding, please help goldkenn Chip Amps 5 21st August 2008 04:20 PM
confusing transformer connections audio_moksha Tubes / Valves 0 13th March 2008 03:07 AM
WE310A, a confusing issue Kenneth Zhu Tubes / Valves 1 9th December 2006 02:24 PM
confusing capacitor value wim Parts 10 28th February 2005 03:23 PM
Copyright 1999-2017 diyAudio
